Question about LG LFC25760 French Door Refrigerator
Slow buildup of ice in freezer
I had a lot of 'snow' accumulating in the freezer. A technician came and said maybe the airflow was blocked and the first thing to do which would probably solve the problem would be to defrost. I defrosted for 24 hours, then reconnected.
After five hours all looked fine, but I could hear an intermittent hissing noise (like when you put a hot pan in cold water) when I opened the freezer. Now, a day later, I can see a very thin layer of ice building up mainly on the rails for the bins, which makes it difficult to open. There is more buildup on the right side than the left. This ice can only be cleaned with a warm sponge. I tried with a cloth and it just stuck to it.
  • 248 Answers
The hissing is normal. It was in defrost.
The frost may be caused by a bad seal around freezer door. Check to be sure seal is hitting properly all around door. Also be sure door is getting closed properly.
Posted on Nov 09, 2007
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Not cooling and making ice
Ice is made when freezer temperature is cold. Freezer and refrigirator will not cool if iced up on back wall. Your defrost system failed, causing frost buildup on the coils and restricting airflow and heat transfer. Most likely cause is a defective defrost timer that is not advancing into defrost (2-3 times every 24 hours). Defrost system comprise Timer, Heater, and Thermostat. You need the tools to diagnose the cause or just try one by one to replace the parts. Other choice is to call a tech. The freezer must be defrosted one time manually to remove the long accumulated frost.
Oct 20, 2015 | Refrigerators
My fridge and freezer not working very well, what can I do?
What Jorge and Bill say, makes sense. On the other hand when old freezers don't perform well, they consume lots of power. New freezers cool better with less power. You could save hundreds of kilowatt a year with a new freezer for their better insulation and higer efficiency.
Apr 18, 2015 | Refrigerators
Fridge of fridge freezer does not get cold (bosch excel KGN34X61GB-05)
Sounds short of refrigerant or very blocked up condenser. Is there a lot of heat from the back/ underneath>
Mar 21, 2014 | Freezers
Exterior of refrigerator between freezer and refrigerator is hot to the touch
It is normal unless there is a lot of dust below your refrigerator blocking airflow. What you feel is hot gas tubes behind the surface of the metal to help reduce moisture around the door frame and door seals that will get hotter should the fan and condenser below refrigerator have a blockage of dust blocking airflow, Sea Breeze.
Jun 17, 2013 | KitchenAid Superba Architect KSCS25INSS...
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
LSC27926ST REFRIG/freezer. Ice maker is leaking water that freezes on items in freezer, ice is messed up and had to unclog ice maker. Still a logjam of ice around ice maker. has been churning out ice...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
Sep 10, 2011 | LG LFX25960ST Stainless Steel French Door...
LG french door fridge - makes hideous noise - loose bearings? - whenever fan is running, which is several times an hour. Any idea what is causing it? Husband tried to grease the fan. It's really...
A broken fan blade can cause a noisy motor. or a buildup of ice can cause some noise. If thes aren't the case you will need to have the fan motor replaced.
Jan 04, 2011 | LG LRFD25850 French Door Refrigerator
Only the freezer is working the bottompart wont
The cooling in the ref. section is done w/ a vent that passes air from the freezer. The adjustment maybe labeled "freezer temp". When you locate it, check w/ hand for cool airflow. Insure that it is not blocked. Set vent control @midpoint and give it 24 hrs to stableize.
P.S. If you have a defrost problem, the coil will frostup and not allow proper airflow. Check rear panel for frost build-up, and check if your freezer can keep ice cream hard. If either, leave unit off overnight w/ doors proped open, then re-check operation.
Dec 30, 2010 | Daewoo Refrigerators
Kenmore fridge over pullout freezer. Freezer has snow. Model 59673502201 . Fridge runs, and shuts off apparently normally. Freezer is cold, air blowing (fan?) from behind freezer temp control. Thought...
Please : - Clean up your freezer - set the thermostat to middle - check the fan for malfunction
There are many things that cause your freezer work abnormally.
Nov 07, 2010 | Kenmore Freezers
LG LFC25760 French Door Refrigerator Logo
349 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
