You should definitely not use aluminum foil in contact with a socket. A few years ago, I tried using foil to fix my garage door opener socket as well and it started to heat up, cause sparks, and nearly caused a fire as well. I definitely think that the best option for you is to call someone who can either repair or replace it. Garage Door Replacement in Williamsburg Virginia
NO. order a new socket. try using a lower watt bulb and not screwing the bulb in so tight the next time.
