Dvd rom driver ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
SOURCE: Both Drivers for CD Roms wont work for Dell Dem 2400
The two devices are both hooked to your secondary IDE channel. It could be that the IDE controller driver is corrupt or missing. Go to the Dell website, download and reinstall the CHIPSET driver, which includes the IDE channels. Then reboot. The driver page is here:)
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Failing that, verify that the drives are visible in the BIOS setup. When you restart and see the Dell splash screen, press F2 to go into the BIOS setup, come down to Drive Info and see if the model is reported for the two opticals. Perhaps it got disabled there, but not likely unless you were changing settings.
Another possibility is whether you removed and CD/DVD recording software recently (Sonic, Roxio, Nero) as these may have changed the registry entries related to your CD/DVD drives.
If nothing works, please post the specific error code reported by the Device Manager. Right click on each drive in the Device Manager and it should be listed in the device status box.
SOURCE: GMA 4082n device driver not working properly code 39
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
SOURCE: Combo Drive LG : CD is not designed to run on Operating System
The 'autorun' sequence to run the disc might have been made for older operating systems. But that should not stop you from installing the driver for the 330 IDSL modem.
1. Go to start-> My computer. Locate your G: drive with the disc inside and right click on it. Choose explore and see if this allows you to view the contents of the disc. If there is a generic application labeled setup.exe execute it. If the application loads the driver for you then your in luck. If not then onto #2.
2. Your modem has been out for a while and has new drivers for it. You can always type in a search "SpeedTouch 330 IDSL modem" and download a more recent driver off the internet.
Example of what I found: http://downloads.zdnet.com/abstract.aspx?docid=458129
SOURCE: My HL-DT-ST RW/DVD GCC - 4243N does not appear to work
Take it to your nearest computer repair shop, as they can remove it and install a new one for you.
Good Luck.
SOURCE: What BRANDS are compatable w/ HL-DT-ST DVD+-RW
My friend as the same burner on is dell laptop and he just burned 2 xbox 360 games on TDK DVD+R DL disks and it worked good but it took about 3 mins to finalize the disk so let your program finish
