Question about Kenmore Refrigerators
I have a 10 yo kenmore coldspot refrigerator. We
I have a 10 yo kenmore coldspot refrigerator. We keep getting water in the refrig...I mean standing water in the veg and cjheese drawer. Standing water in the shelves, etc We have cleaned/defrosted the drain in the freezer section several times with no improvement. any ideas on whats wrong and how to fix it? Thanks
  • dar Bouchar Jun 30, 2009
    the model number is 106-77188791
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Posted on Jul 11, 2009
I have a Kenmore Coldspot refrigerator with top freezer. The icemaker is "leaking" if it is the right word into the ice tray bin that it is building a chunk of ice along with the regular ice...
What that sounds like is the water valve isnt fully closing. This tipi wrote is about that issue,
http://www.fixya.com/support/r10343350-icemaker_drips_causing_all_ice_freeze
Reply with your exact model number as found on a label usually on the ceiling of the refrig. compartment and i will give you the part number for that water valve.
GENE
Sep 05, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
A side by side kenmore coldspot the freeze is getting cold the refrigator side is very warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
Freezer fine refrig not very cold kenmore coldspot 71984100
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 19, 2010 | Refrigerators
Kenmore Coldspot #106.9750610. Icemaker does not
restricted water flow or pressure from house water where your taped into. your shut off or Tap a line may be cloged or if you have a water filter its cloged. It could also be a bad water valve in rear of refrig. start at the sourse of water and work back to frig. A rare thing could be that the timing gear on the ice maker is burnt and not trigering valve long enough to fill icemaker
Oct 30, 2009 | Refrigerators
Model 78182891 Coldspot with excessive water Collecting in Refrig
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair:
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post bak if you have any questions and I'll gladly help you out Thanks Peyton
Mar 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Ice maker works, water dispener does not
There is a switch in the door where you get water which activates the water valve in the back.
One or both of these are bad.
Jun 06, 2008 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
906 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
