Question about ASUS AMD 760 MP Chipset A7M266-D (A7M266-D/PA-UAY) Motherboard
Windows Instalation No instale Windows
Re: windows Instalation
Change the windows version
or change the ram
Posted on Nov 08, 2007
0 characters
3 Points
I am installed windows7 but when full instalation completed my pc restart windows7 does not open when i open pc restart rotedly
what restart rotedly ??
if your computers motherboard is 5yrs or older it will not support windows 7
you will need 2 GB of ram minimum to run windows 7
hope this helps
Oct 23, 2011 | Intel D945GCNL Motherboard
I have lost my mother boards CD.For this reason unable to windows instalation
To better help you address you issue I need to know the model and service tag of your Dell computer. Also include the what version of Windows came with your computer.
Oct 06, 2011 | Dell Motherboards
Hi. i have g41m combo i cant install windows the last 7 miniutes of instalation the pc brakes... when windows is saving files:S
Hi, you can download a manual and drivers here:
My guess is that the windows disc is damaged
thats why the installation stops.
Your mainboard can run windows 7.
Consider that instead of the old xp that soon expires.
Aug 23, 2011 | Gigabyte GA-G41M-Combo Motherboard
I cannot install my webcam. I don't know how...I can't find the driver for the webcam's from intex(it-104wc).Thank you anticipated!
Driver for that model can be found here:
It has been removed from Intex Technologies main product page, but the drivers are still available under the name Webcam Classic.
These drivers will only work with older Windows versions up to Windows XP. If you have a newer operating system like Vista or Windows 7 you will need to purchase a new webcam.
Happy Computing, Myridom
Mar 05, 2011 | Motherboards
I have a biostar motherboard G31-M7TE with XP the instalation disk installs USB 2.0 ok, but now i installed Vista and planning Windows 7 too , but actually with Vista my USB is 1.0, too slow, it...
Access the Windows DEVICE MANAGER.
Select the USB hardware.
Click UPDATE DRIVER, and see if Windows Update can download and provide the correct device-driver to enable USB 2.0 support on your USB 2.0 ports.
Or, try: and see if the updated USB device-driver is posted on their "Support
May 19, 2010 | Biostar G31-M7 TE Motherboard
I use WINDOWS XP SP 2...mainboard MSI N1996,
It is fault in Ur Windows firstly repair Ur windows then install driver but recommended restore backup must.
Feb 15, 2010 | Motherboards
Intel 82801EB Driver Need after a Windows XP Pro Instalation
get a friend to download intel chipset inf file from intel for you....
Apr 05, 2009 | Motherboards
Winxp instalation
There is not way to install a windows xp os without SATA drivers. If you don't want to use the floppy disk to make the os recognize the HDD, you can integrate the drivers in the Windows Xp installation Cd, using software like Nlite.
Another solution is to use a IDE HDD, the old kind with the 80 wire ribbon cable.
Mar 31, 2009 | VIA ASUS A7V600X MB AMD KT600/ 400FSB/...
Problem installling Windows xp SP2 with P4VMA-M Mainboard
If your trying to install it over the current installation then select Format at the installation screen of XP setup. In order to do that you would have to boot from the disc, that way you don't have to load windows. Also when you have completed and installed XP, try to locate some software to detect what drivers you need. I use driver detective and it worked fine for me, or alternately send me a message and ill run you through how to check the motherboard for the version manually.
Mar 09, 2009 | Biostar P4VMA-M Motherboard
My PC doesnot work properly when I install windows XP. Current PC config: 512 MB RAM 80GB Hard Disk Intel D845gvsr Chipset Motherboard
i have no idea if you are using windows cd that it came with your pc or you are using retail cd ??
but you can take these steps to have clean instalation, make sure your windows cd has gunian serial number(becouse you will not be able to update your windows after instalation).
if you have recovery disk from Brand of your computer(example:
dell ,or hp ,or......) use that for instaling windows, it will bring your pc to the day when you bought it. if not
and using retail windows cd , please do as a follow:
first backup all your documents ,wher you can download them after fresh windows,becous you will lose the when instaling new windows.
put your windows cd in cd drive ,
restart your your pc
when rebooting it will ask you if you want reboot from cd or dvd(as soos as you see that you must act quik) click enter
then follow on screen until it will ask you to chose how to format the partition that you are instaling windows , PLEASE chose full format .
now follow the instruction until windows comletliy instaled .
update your windows
now you are good to go for any other things you like to instal.
Dec 14, 2008 | Intel D845GVSR Motherboard
ASUS AMD 760 MP Chipset A7M266-D (A7M266-D/PA-UAY) Motherboard Logo
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
