Question about HP LaserJet P3005 Printer
Printer will stop printing and you have to turn it off to make it restart? What can I do to repair the problem?
    Problem Solver:
  • 6 Answers
It looks like a communication issue. It seems that the printer is quiting to communicate with the computer intermittently.
If the printer is on network, you may want to reset the printer IP address and reinstall the printer driver to test.
Cold reset unlocks menus that have been previously locked and sets all control panel menu items (including EIO settings) back to the factory defaults. However, it does not clear the values in the
SERVICE
NOTE: Before performing a cold reset, print a menu map and a configuration page
1. Turn the device off.
2. Turn the device on. When the memory count begins, press and hold the check button. Continue holding down the check button until all three device control-panel lights flash once and then remain on. This might take up to 10 seconds
3. After the message SELECT LANGUAGE appears on the display, press the arrow up and arrow down buttons until COLD RESET is highlighted.
4. Press the check button. The device performs a cold reset and then continues its power-on sequence.
5. Check all I/O settings and reset any customer-set device configuration values.
Print a configuration page from the Printer INformation Menu after restarting the printer. The IP address would ideally be a different one if your network is a DHCP network. If not, you will have to manually configure the IP address on the printer. You may do that by accessing the Configure Menu on the PRinter control panel.
Try configureing the printer driver to the new IP address. It should solve the issue.
If that doesnt work, you may want to download a new driver from the website and install it.
Posted on Aug 27, 2009
What does the User Intervention on a Dell 2130CN printer mean?
Either the print was stopped from printing. check print queue.
Or the printer was turned off during print
Open the inspection doors
pull out ink cartridge, put back in
Check for paper stuck in printer
make sure you print Queue is empty
remove usb and turn off pc
restart and plug usb back
Mar 11, 2015 | Dell 2130cn Laser Printer
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
The printer will not cancel a print
cancel via printer options in windows.. and turn off the printer... turn it on again.. hopefully it will solve your problem
Mar 01, 2011 | Lexmark X7550 InkJet Printer
Hp 4250(on a network) is hung up on processing job. I restarted the print spool and physically restarted the printer put the problem still exists.what should i do
you may need to turn off your print services on your pc. pull up the printer que on the pc. delete the jobs in the que. right click my computer. go to mange. go to services and applications .go 2 services. double left click. look for print spooler. right click. choose stop. then go to printer and reset job. turn off printer. turn on printer. restart your print spooler. close all windows and try to print
Jan 07, 2011 | HP LaserJet 4250n Printer
Is there a way to reset the printer if you want to stop a job midway when i print a report? OKI Pacemark 3410 Matrix
yes, clear all print jobs in the print queue on the PC.
The press "Stop" on the printer.
2. Turn the printer off for 1 minute the restart
3. Shut the PC down and restart.
This will clear the memory for both devices.
Apr 16, 2010 | OKI Pacemark 3410 Matrix Printer
My printer is printing without anything in the printer
go to the printer properties clear the queue and then stop the spooler services and then restart the services .... and your problem will be gone .....
Apr 14, 2010 | Lexmark X2600 InkJet Printer
I am attempting to delete a print job on my psc 2210 but after waiting 12 hours it is still there blocking other print jobs I'd like to make. How can I delete this one?
Go to Start, Control Panel, Administrative Tools, then Services. Scroll down to Print Spooler. There are 2 selections on the left, Stop and Restart. Go ahead and hit Stop. Once it does, click delete on the printer screen to get rid of the unwanted document. Then click Restart to start the spooler again. This should work.
Mar 04, 2010 | HP PSC 2210 All-In-One InkJet Printer
Waste ink absorver is full
kindly follow this steps to fix the error
Reset manual "Ink Absorber Full" for pixma
Steps by steps how to reset :
1. Turn off the printer but still connected to a power source
2. Press stop/reset button, and then press power button to restart
3. Press power again and then press twice the stop/reset button.
4. Press power & Stop/reset button together, to enter
the repair status and power lights will be green,
5. Press stop/reset button
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
6. Turn off the printer
7. Unplug the power cable.
8. Plug the power cable and then turn it on again.
Nov 12, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Wont print or only few pages
sounds like a Mpcb malfunction.(expensive now its out of warrenty) you can replace the printer with what the repair
would cost you.
Jun 11, 2008 | Brother HL-2040 Laser Printer
Will not print after turning printer off
I used to have that same problem what i suggest doing is restarting not only the printer but your computer aswell. That seemed to solve the problem for me
Oct 15, 2007 | HP LaserJet 1020 Printer
HP LaserJet P3005 Printer Logo
270 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
