Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Light on inside of refrigerater works sometimes. it just goes off sometimes for days then it will come back on
  • 40 Answers
Sometimes light is used as a heater function in the appliance inorder to keep temperatures stable.
But it is also possible that your door switch is not functioning correctly.If you suffer from bad performance this can be the reason.
Posted on Jul 01, 2009
My Samsung RB215LASH Refrigerater the freezer is set at -2 was on 8 and the door was left open for most of the day, it seems that know it is taking forever to freeze
It may take up to 24 hours for it to get back to normal and stabilize again...also don't be surprised if a bunch of water runs out the bottom when it goes to defrost the next time... you left a lot of humidiy in there with the door open...
heatman101
Apr 21, 2011 | Samsung RS265LBBP Side by Side...
GE Medallion 850 Frige does
Can you please explain the issue in detail?
Oct 05, 2008 | Refrigerators
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Jan 20, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Ge refrigerater side by side is making a wining noise that sounds like it is coming from the freeser. We tok the back off and cleaned out the dust and it stopped for a day.
The fan in the freezer is either dirty, failing, or hitting an excessive ice buildup.
Take the plastic panel inside the freezer off and look at it.You can actually let it run for a few moments with the plastic off so you can watch.
Jul 08, 2009 | Maytag MBF 2256 Bottom Freezer...
GE refrigerater stops cooling/freezing and restarts?
maybe stuck in defrost cycle. usually controlled by a hv board on rear of refrigerator
Jun 21, 2009 | GE Refrigerators
Refrigerater Light
Hi there check plastic angle bracket on bottom of door is not broken as it pushes the fan/light switch.Hope this helps
Dec 12, 2008 | Kenmore 53642 / 53644 Side by Side...
Not cooling
Sometimes when the evaporator fan goes out, it takes part of the motherboard also. (part number WR55X10552, which also subs into a WR55X10656) If this is the case, I would not expect the refrig to be running either. (If your compressor still runs, check door switch.)
Dec 09, 2008 | GE Refrigerators
Refrigerater not staying cold and coil is frozen. condenser and fan are working freezer ice machine not working
The tube between the freezer and fridge is also likely to be frozen up. You need to unplug the unit for a day and let it thaw out. When you plug it back in, start with a low to med setting on the temp.
Geno
Aug 02, 2008 | Maytag Refrigerators
Maytag refrigerater
If you have an ice maker in the freezer compartment try raising the bail arm and shutting it off. It is possible that an ice maker will increase your run time.
May 16, 2008 | Maytag Refrigerators
Fan works light works but no cooling in either the freezer or refrigerater
The fan in the back of frig will run. Try replacing the evaperator fan and if the evaporator fan does not work replace the thermostat.
Jan 09, 2008 | Kenmore 53092 / 53094 Side by Side...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
112 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
