Question about Frigidaire FTF2140E King-Size ENERGY STAR
Water in the drum
After completing its washing cycle,water stillin the drum
My front loader will only start up for a second and then shuts down. I have already taken the water pump off and found no debree in this area . Any Ideas.
Posted on Jan 25, 2010
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
Posted on Jul 10, 2009
SOURCE:
Drum will not empty water
sounds like its not going thru the complete spin cycle and empty could the timer control switch its all intergrated in one all the the different application s the cycles goes thru all report back to the timer control switch and when the cycle is complete the timer goes to the next cycle i f the timer is defective it well keep on going reguardless and go to the next cycle unfortunately the cost will run around 250.00 for the part good luck
Aug 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Not completing cycle - water left in drum - how do I empty it
hi
yon need to remove filter and clear any debris which is in there and check the pump impeller is turning ok.
regards
Mar 21, 2009 | Zanussi ZWF1430W Front Load Washer
Water stays in drum after cycle is complete and odor
I think from what you have said, that you have a pump problem. The water pump on most washers collect all sorts of bits and pieces including small coins. You may be able to clean out the pump if it is not a sealed unit.
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
All washing just smell worse when washed
there is water laying flat somewhere that will not drain completely. thoroughly check the drain hose in the back...any kinks?
Jun 07, 2007 | Hoover Nextra HNF 2137 Front Load Washer
Frigidaire FTF2140E King-Size ENERGY STAR Logo
102 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
