Question about NetGear WG511T 802.11g/b Wireless Adapter
Wg511 v2 'sees' the network but just won't connect just keeps scanning, updated to latest driver but still no go. Pulled out old WG111 v2 USB wireless card and it connects straight away. Pull the Wg111v2 out and reconnect the WG511v2 and the same issue. Could the WG511v2 'see' the network, but some how not connect? Everything has been checked three or so times, such as WEP Key and used as a Paste - which worked first time when given to the WG111v2! Stuck for ideas, although the WG111v2 is working it sticks out the back of the Dell Latitude - the WG511V2 card is easy to use. O/S XP Modem THOMSON TG585 v7 however same probs with the 3Com router modem as well.
  • 1,272 Answers
Follow the step below to configure wireless connection.
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 04, 2009
  • adxelec Nov 12, 2010
    This solution worked fine in XP, but unfortunately doesn't exist in Windows 2000. We're stuck wth with Netgear's broken driver helper.
Adaptor won't recognize wpa2 network
As per its user manual (p 2-1)
it only supports WPA, not WPA2
So either reduce the wireless network security to WPA/PSK, or get another adapter that supports WPA2
Or, If it's a version 2 in hardware, you could download the latest driver V2 that added the WPA2 support
Good luck
Jan 08, 2013 | NetGear WG111 802.11g/b Wireless Adapter
WG111 v2 cuts in and out of connection. says scanning for network address. has been working for three months. i have tried everything i know to fix it. thanks chris
Check the wireless access point you are using for problems. If someone bought the same brand near you then they may be using the same channel which would cause the problem you are describing. In that case change the WAP to use a different channel.
Good Luck!
Oct 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wg111 usb adapter
Since you already did a uninstall and re installation of your adapter and still the same problem, you may want to try updating the driver of the adapter, so uninstall and reinstall the adapter using the latest driver from the manufacturers web site....
Nov 30, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
How can i
Try this link
http://kb.netgear.com/app/products/model/a_id/2556
This is for version 1.0 If you have version 2.0 or 3.0 you will need a different download that can be found on the website.
Mar 02, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111 v2
go to manage wireless networks.. click on the network name choose manually configure.. set your wep key in there
Jan 06, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NETGEAR WRN 2000 - WG111 keeps scanning
i try to dowload the driver for a wireless usb adapter wg111t only one i see his detective one
Oct 07, 2008 | NetGear WG111 802.11g/b Wireless Adapter
My signal is very slow . stars in 56mb and go down to 1 mb and still there, i have a netgear WG111 v2
I want to tell you that to get a best performance for this adapter you can simply download the latest driver for the adapter and also make sure you dont have any interference device. Please try to change the channel on the router so that if you are getting any interference through any device it can be avoided regarding that.
I believe this will be help you to resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Jul 24, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
WG111 see network but won't stay connected
I would ensure that the product is operational by swapping it with the other WG111, then ensure that you have the card setup properly, make sure you have the lastest drivers from Netgear, I have fixed some problem with the WG111 in this fashion. If that fails then I would try upgrading to a 2.0 usb. i'll try to see if I can create this with and old machine I'll keep you posted
Nov 04, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NetGear WG511T 802.11g/b Wireless Adapter Logo
1,067 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
