Leaking water from underneath.back left side only when fillimg up for wash cycle model no. A283 OR 1282 HARD TO READ SERIAL NO. 1006231
  • vickiecarpen Jun 30, 2009
    i ckd the hoses all secure i lifted up the washer there is a hole underneath where the back left leg is. the hole is where the water is leaking. it is not a hole that does not belong there. it looks like part of the washer
  • 258 Answers
Check over your inlet and outlet water hoses, there is most likely a leak somewhere
Posted on Jun 30, 2009
  • cmitchell3 Sep 19, 2009
    Sorry disregard that, INJECTOR NOZZLE is the correct name, the replacement part number is 12001677 ,there are two screws in front lower panel of the washer, remove and swing the panel up from the bottom to release the tabs and remove the panel, this will allow the top (lid panel) to raise up like the hood of car, the part will be in the top left corner where your leak is, white plastic with black hose's attached.
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
Why would water come out from underneath washer?
u have to access the inside of ur unit by opening the sides ... if not dangerous run the unit and monitor it during draining mode ... same procedure also w/ the loud motor ..... by that way u can pinpoint what cause those problem
Aug 05, 2014 | Amana Washing Machines
Water leak from model 110 washer
Good Afternoon Doris, thank you for your post!
I understand your washer model 110 is leaking. However, it appears above-listed model number is invalid. The serial tag, which lists your model number, is typically located on the upper front, as you open the door.
Is your washer leaking through the back, from the side, underneath? With this information I can better address the issue at hand. Thank you!
Nov 25, 2013 | Frigidaire ATF6000ES Front Load Washer
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
