CA
Cl
Average current limit Or
Instantaneous current limit
If a status signal comes back from
the motor controller that a current limit has been breached, the unit
will return to standby mode and display either CA for average current
limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of
current draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal
protector, or motor controller. Over-loading the unit may cause this
problem.
I have the same thing on my board. I plan to replace the 2R025 current limiter which you can purchase from Newark or Digikey online. You may want to check the capacitors also (big cans mounted side-by-side, 15000 microfarad, 35v). These also can be purchased. It is worth a try, $14 vs. $230.
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem."
Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Error code C1 indicates problem with drive motor-thermal protector-or motor controller Overloading may also cause the problem. Press( stop/cancel) to clear the display.If that does not help then,"C1 = Average current limit Or Instantaneous current limit." If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.You can get required parts from www.repairclinic.com Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
how are u am scott hope i can help ok i have the same washer this CA code means AVERAGE CURRENT LIMIT, OR INSTANTANEOUS CURRENT LIMIT. if a status comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip, or "CI" for instantaneous current limit trip. AVERAGE CURRENT TRIP occurs if there is a 2-second average of current draw greater than 5.55 amps at the motor windings. INSTANTANEOUS CURRENT TRIP occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. or overloading the unit may cause this problem. press stop/cancel to clear the display good luck
Hello there: the ca or even a ci can mean the following
CA
Cl
Average current
limit Or
If a status
cause this problem.
Press STOP/CANCEL to clear the display unplug the machine for 1 hour and then plug back in and see if the error is now cleared
Cl Average current limit Or Instantaneous current limitIf a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Hi, The C1 code signifies "Average current limit Or Instantaneous current limit."
If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or C1 for instantaneous current limit trip.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem. " Please check down the drive motor to resolve the issue. Have a blessed day! Thanks! mannu_rakesh
