Installation instructions?
SOURCE: drivers don't install on macs OS10.5.7
Please check if your driver is supports the Mac OS then if it is not supported by your current system please find or download driver that supports the MAC OS. You can search using www.google.com.
Thanks
SOURCE: laptop wont boot up after installing Genius F610
you need to run a nifty little program called Spinrite on your laptop. You can download it via BitTorrent HERE
you will need to use a program to burn the ISO image onto disk and make it bootable. I use PowerISO . It is very easy and straight forward. You can download it HERE (use the name: Dr.Upload
serial: SKSIP-7AIX1-8YWEZ-U197K-T88IE ) to remove restrictions.
Open the iso file using PowerISO. Now we have to make it a bootable disk image. Spinrite comes with FREEDOS instaled, but most laptops don't like using it.
Follow directions here on making a bootable image.
after burning your disk boot your system up with the cd. when you get to a prompt , ie C:\\ you will need to change it to your default cd drive mine is E:
after changing the drive letter type SPINRITE
the program will start - follow onscreen directions and change scan level to 5. after program finishes reboot after removing disk.
SOURCE: Replacement Pen for G-Pen F610 isn't working very well.
nomally happens the 1st time you use.
log off and back on again.
otherwise reset ... it should work next time you boot up.
