Question about PreSonus Firebox 6x10 External Sound System
Very low output volume from Presonus Firebox recordings
Hi. This is very frustrating. I've connected a Shure SM58 and am using Cubase LE 4. It's recording just fine, and I can monitor during recording just fine. The volume to the earphones while monitoring is also just fine. The problem is somewhere in the export of the audio mixdown. The result is very quiet, and even when I turn up the volume on any/everything I play the resulting file on, it's still very quiet.
I've tried doubling up the tracks and that helps, I've even done it up to five time with okay results, but it's still too quiet.
I've also raised the gain to the max in the Cubase LE4 mixer. Again, it helps, but not much.
This is really urgent because I've been asked to provide a voice sample and vocal sample for studio work, but they can't use the samples I'm sending them due to the low volume.
A bit of additional information: I have the input volume for the mic on the Firebox turned almost all the way up (around +25 dB). If I turn it up to +30, I get clipping. I've also boosted the input via the Presonus Control Panel. I'm exporting the mixdown as mp3. For some reason, the exported wav files don't seem to work in standard players.
Any and all advice appreciated!
Thanks in advance!
Joanna
I do'nt know the name of the sound driver installed in my PC
Posted on Jun 30, 2009
Trouble with the Shure SM58 Mic.
Hi Ian,
i think the problem is with recorder or recording volume setting.
please check.
regards.
nuwan
Jan 10, 2014 | Toshiba Computers & Internet
Just got shure sm58, plug it into my starsinger on the tele but sounds is very low compared to the crappy mics? i plugged up a mixer box and can get more sound now but should it work fine with the...
The SM58 uses balanced output. If the starsinger uses a 1/4 inch jack, it is unbalanced input and probbly requires a high impedance rather than the low impedance SM58 mic. You can get an impedance transformer to fix that problem.
Dec 13, 2011 | Shure SM58 Professional Microphone
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Apr 04, 2010 | Shure SM58 Professional Microphone
No output
Make sure you have your speakers connected to the main output. Also, in the "Universal Control" "Mixer" window, make sure that at least one of the mixes are assigner to "Mo", which stands for main output.
Feb 03, 2010 | PreSonus FIRESTUDIO Sound Card
Vista 64 bit audio engine will not start. cubase
If you're using the same software on the 32 bit and the 64 bit, that's probably the problem. You could find the right software for your version of Windows if you searched online or at the manufacturer's website.
Dec 03, 2009 | Steinberg Cubase 4 ( Windows / Macintosh )...
I am getting a lot of hiss when I record low
it is not a problem there are many problem
Aug 23, 2009 | PreSonus Computers & Internet
Cubase shuts down every time I try to process a recorded file
Hi Melimiti,
You are not the only one with this problem. Cubase is quite a complicate software. If reinstalling does not help we need to have a CLEAN Install on a new OS. If the problem still persist contact the vendor for the product exchange.
Jan 22, 2009 | Steinberg Cubase Recording Software...
Trying to install firebox software /get i/o error on laptop
plz check with other cds if the problem persist then try with another data cable. if the problem is not solved try with another cd rom
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Firebox and cubase se not workin
https://www.steinberg.net/1069+M52087573ab0.html, If u have purchased the software,just go to this this link,register ur product. U will get the steinberg cubase customer care, just try contacting them and rectifying the problem, because this is too specific and technical.BEST OF LUCK!!!! THANK U!!!!
Jun 21, 2008 | Steinberg Cubase SE
Hi which version of Cubase you are using / have you download it from somewhere or Just bought it ?
Jan 19, 2008 | Steinberg Cubase SE
PreSonus Firebox 6x10 External Sound System Logo
786 people viewed this question
Top PreSonus Computers & Internet Experts
Greg Ulan
richie46
Tom Chichester
Are you a PreSonus Computer and Internet Expert? Answer questions, earn points and help others
