Question about Ovens
Maytag wall oven overheating
I have a maytag wall oven model #MEW5527DDW. It is overheating by about 100 degrees. What are the possible causes for this?
  • 4 Answers
Have it cleaned
Posted on Jun 30, 2009
I have a maytag wall oven it shows error code f2eo what does this mean and how do I fix it?
E0 F2 is usually a stuck key on the keypad. You will need to replace your keypad most likely. It's possible to be caused by the control board also. If it is NLA we can rebuild it for you at fixyourboard.com
Aug 13, 2015 | Maytag Ovens
Maytag model number mew6527dds when you turn to bake the broiler comes on
The oven control board is defective--most likely the electronic control chips have been damaged and are causing a crossing of the functions.
Sep 08, 2014 | Maytag 30" Built-In Single Electric Wall...
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
Maytag 30" PGR571DBDQ stove. Oventook over 30 minutes to reach 350 degrees
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 13, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Oct 20, 2009 | Maytag 30" Built-In Single Electric Wall...
The oven touch bottoms are starting to not work acouple at a time do you think the control panel is going or is it the control box be hind it . Model mew5527ddw maytag wall oven
it certainly sounds like it's just the touch pad/membraine that may be going and not the timer/control by your description. does the touch pad visually look worn, i.e.cracking, discolored etc. ? there is a method to check those membranes with an ohm meter and about half a dozen hands, ha ha. (just a side note, on the control where this component plugs in can become contaminated with dirt and grease as well as other debris, at times I've been able to successfully clean the "ribbon connector" with some alcohol and a pencil eraser). but I'd suggest you call a tech if it comes to that.
the panel itself should be part # 5765M482-60. that is again based on info you provided, specifically the model number. also it will likely be packaged indicating it is a "whirlpool" item, don't worry, maytag is now under the whirlpool juggernaut.
hope that helps,
good luck
Sep 28, 2009 | Maytag Ovens
Maytag oven calibration
Maytag single built in oven model cwe9000bcb beeps intermittenly. Reset stops for about 1 minute. Two control panel boards replaced since 2002 with same problem. Can it be fixed?
Dec 18, 2007 | Maytag CWE4800A Electric Single Oven
Ovens Logo
153 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
