Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
Laars Lite spa heater leaking at header after reconnected plumbin
I have a laars lite 2 spa heater that I needed swap the input/output header from the right to the left side. Once reconnected to the new plumbing, both the input and output pipes are leaking at the connection to the header. I used new 2" flange gaskets and sleeves to no avail. When I tightened the flange bolts, the 2" flange gaskets (which seemed a bit too large), did manage to slip into place. Since they were both leaking, I removed the connections, and was surprised that the flange sleeves were dimpled in one place, as the inside of the header has some kind of obstructing tab. This was true for both the water inlet and outlet. Are the bolts not meant to be tightened down all the way?
I also tried the old gaskets, which were pretty worn. They also leaked. They seemed to have a smaller inner diameter, and there was no sleeve present.
I am using factory parts (as per the manual), to no avail. Any suggestions?
  • 990 Answers
Old laars heaters had only 1.5' Flanges. Newer ones had 2" and 1.5" the difference being the inside hole. so you can get 1.5" gaskets 2' by 1.5" gaskets and 2" gaskets. If you have stanless steel heat sinks wich I think you may have you need to match the right gasket to the pipe size. The gaskets should slide over the pipe easly and snug firmly when you tighten them. Then be sure you tighten each one eavanly. The obstructing tab is there to keep 1.5" sinks from going in to far and interfearing with the by-pass assembly.I hope this helps, I know what I'm talking about and it sounds confuseing to me.If you measure the hole in the flange and the size of the pipe and get gaskets that size you should be fine. Good luck.
Posted on Dec 21, 2009
Teledyne laars leaks excessive water. is it dangerous?
if not leaking over flame ok to use but you need new heat exchange
Aug 03, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Leaks
check gas pressure if not correct will overheat and will start leaking
Jul 07, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Heater will not go on
make sure little pump is moving if not check syphon tube going to pressure switch if ok check pressure switch
Jun 29, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
How do I test a honeywell TS8205A controller form my Laars 2 lite spa heater?
Try downloading this doc. Be sure you follow the right model number some are a "T" and some are "TS".
http://vancontrols.com/pdf/hw/TS8205.pdf
Apr 14, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I need a manual for laars lite 2 125000 btu
Go to the Jandy web site, there you can look up your model and down load a pfd manual free
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
175 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
