SOURCE: how to replace actuator on F350 V0
My right sliding door's lock doesn't function either. I took off the door panel and found that the lock mechanism was broken. Normally I would think this strange, as the lock mech is metal. But since this is a Plymouth product, I some how think it should be normal for something to break off without it ever getting a direct hit. I can only assume that my kids closing the door too hard might have had something to do with this. Anyway, the whole lock mech needs to be replaced, and I haven't even tried to see how much that will cost me. This Van has cost twice in repairs than what I paid new for it. (just kidding, but it sure feels like it). If you have an answer to this query
SOURCE: F350 V10 starts but falters and dies
You also might want to check the fuel relay, see if it's been burnt out.
If the truck is still having issues, you might wish to look at the TPS (throttle position sensor). If it's sitting at too low of a position (broken spring usually), it could be killing the truck.
SOURCE: my 99 f350 v10 wont start. starts fine for a
You have replace filter-assuming air filter?
Throttle control? Are you checking to make sure you have Fuel spraying after you crank the engine?
1- Let's check this. AFter cranking for a while.
2- remove spark plugs see if it wet.
3- it if is, you have fuel Go to # 5
4- It if is not, then you don't have Fuel. Need to fix this.
5- Plug the spark plug as it supposely connected, but not screwing in. Hold it against the chasis and crank it up to see if it sparks. Need a helper.
6-If there is no spark. Need to fix this.
7- If your spark plug is wet and there is also spark, report back then I will provide next diagnoses. Good luck.
SOURCE: f350 fuel pump relay 2004 gas v10
check for power to the pump first ,then if it has power check for earth ,could be immobilisor has cut in..when checking for power to pump use a seperate earth for the meter ,because if the immobilisor cuts in it stops the earth to the relay stopping it from working
SOURCE: 2006 ford f350, leaking fuel at the fuel filter
must identified what part of it is leaking has it been changed and wrong or wrongly installed gasket promble
