Question about Sony BRAVIA KDL-52W3000 52 in. LCD Television
Hi, I have a Sony Bravio KDL-52W3000 LCD TV, which shows vertical lines about 1/2 inch apart from each other, throughout the entire screen. The lines are not fixed and flicker. Also the "Disply Area" settings only shows normal, -1, and -2 with no full pixel option. Any idea?
  • 197 Answers
Could be a bad bu pcb or a bad panel call sony probably still under manufactures warranty
Posted on Jul 01, 2009
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
The picture is too big for the screen and i can't get it reduced
Change aspect ratio of screen through screen format option in Menu.
Hope this will fix your screen size issue in Sony KDL-52W3000 tv.
Thanks.
Dec 27, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Nov 26, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
Aug 14, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Lines across tv
try cleaning T-CON Board to Lcd panel cable
Jul 23, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Picture problem
This is not a solution but a correction . I stated that there was vertical lines but that should be horizontal Lines. I am having a tech come tomorrow to look at it as it is still under waranty.
Thanks
Jan 27, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony BRAVIA KDL-52W3000 52 in. LCD Television Logo
529 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
