Question about Hotpoint WMA30 Front Load Washer
How do i change the brushes on my wma35 hotpoint washing machine so that it'll spin?
    Sergeant:
    Champion:
  • 353 Answers
Unplug first then remove top cover motor should be there remove motor 2 bolts then u can change brushes
Posted on Jun 30, 2009
How do you change brushes on hotpoint wma35
Posted on Dec 20, 2009
Machine washes but won't spin
Hi
There are various reasons when washer won't spin.Please check the bellow link to troubleshoot your problem:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Hotpoint WMA35 Front Load Washer
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
The top off Hotpoint WMA35 washing machine?
Located at the front end of the top cover, are 2 plastic covers, prise them out with a small screw driver or something similar, and inside are 2 torx screws, get a torx screwdriver, and undo the 2 screws, if tyou don't have the correct screwdriver, you may be able to undo them with a small screwdriver.
Give the top a good hard push towards the rear, and it should come off..
Hope this helps.
Dec 28, 2009 | Hotpoint WMA35 Front Load Washer
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
i would get a new door or catch from the hotpoint website hope this helps
Jan 24, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA35
Remove lower rear cover of washer, remove belt, undo 2 screws securing motor, remove motor wiring plug,, lever back motor and remove motor.
Remove carbon brushes at end of motor, and check for wear, if less than 8-10mm long, then replace them.
Clean armature with emery cloth or sandpaper before fitting new brushes, if it still does not work then the motor is probably faulty.
Plz rate my solution.
Thanks.
Jan 23, 2009 | Hotpoint WMA35 Front Load Washer
HOTPOINT WMA35 WASHER
remove it from power plug it off from 24 hours and then use it again
Jun 09, 2008 | Hotpoint WMA35 Front Load Washer
Cleaning my machine
i have a maytag washer, when i wash clothes ,it is starting to leak from the bottom.can you tell me what the problem is.
Mar 31, 2008 | Hotpoint WMA35 Front Load Washer
Motor brushes?
I am not familiar with your specific washer, but there are some washers that has a hole in the bottom that allow you an access to the brush. In case you don't have this access (I hope that you will have !) you should take the motor off for it. Good luck !
Jun 12, 2006 | Hotpoint WMA35 Front Load Washer
Machine sticks on prewash
pls change the poer supply board
Jun 01, 2006 | Hotpoint WMA35 Front Load Washer
Hotpoint WMA30 Front Load Washer Logo
426 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
