Question about Proview PL482S 14 in. Flat Panel LCD Monitor
How do I connect my 482s to PS2 or other video game systems? Is there a converter for the pin connector?
Connect ps2 to tv
Most new TV's are coming out with only HDMI inputs. If your TV has only HDMI, and a (cable) in, Then there are 2 ways to connect your PS2. 1) Buy a rca(audio/video) to HDMI converter. These are available on Ebay in several different designs.2) Buy a PS2 cable ready coaxial converter available from Ebay, or your local gamestop store. Remember, the cords for the PS2 and the PS3 are EXACTLY the same.
Aug 06, 2014 | Sony PlayStation 2 (PS2) Console
How do i connect a computer mouse to a samsung notebook
what's the mouse connector? is it PS2 (a round connector with pins on it)? or USB?
if it's USB,you can directly connect it to your notebook,if it's PS2,then you need to use a PS2-USB converter,it's cheap
Aug 23, 2012 | Samsung N150 Notebook
I can't get my PS2 to connect to my dual xdvd270
You can connect the PS2 Video out (composite video out) to any of the 2 monitors video connector and the audio at the audio connector, remember to select A/V ext (External Audio and video) both video and audio uses 3,5mm jacks, if it does not work you might need to try to draw out the jacks a little, the connectors are of poor quality so be carefull.
You also might want to check if the right system is selected PAL/NTSC, check the format from your PS2 and set the monitor to accept the same signal type, then it should work fine.
The only thing I am not sure how you do is to get the composite video out of the PS2 but study the manual or google and you will find it I guess, but my guess is that you allready have that part covered.
Jan 03, 2010 | Dual XDVD270 Car DVD Player
Audio, but no video on PS2
Try the system on another TV. If this doesn't yield any results, then you may need to get the console replaced.
If you can see video on the other TV set, try to connect the console to the TV directly, rather than through the A/V ports on your DVD player or HD converter box, as this can sometimes cause more harm than good.
Nov 06, 2009 | Sony PlayStation 2 (PS2) Console
My dell sk8110 keyboard has a round purple connector plug that fit my old computer. My new computer has only USB ports. How can I connect my keyboard to the new computer?
http://www.microcenter.com/search/search_results.phtml?keyword=usb+adapter+ps%2F2&category=
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
Aug 24, 2009 | Dell SK8110 Keyboard
Connection a ps2 thru the vcr to tv
i know wat youre talkin bout.I had a tc to which i couldnt connect my dvd player.
There are 2 possible solutions...
1.You can get an analog converter.At least i think thats wat its called.it connects the ps2 wires thru the converter to the big fat pin of your old tv.It will work.
2.Sorry bro...you gotta buy  a new TV.
and if i helped u solve ur problem in any way...please help me by clicking on the fixya rating..
thank you.
Mar 09, 2009 | Sony PlayStation 2 (PS2) Console
Playstation 2
Set it on video mode, or check the connections to the TV.
May 01, 2008 | Sony PlayStation 2 (PS2) Console
PS2 on a LCD
You will need to go to your PS2 system configuration screen and change from RGB to YPbPr component video output. The 1920ex (remember to switch source to YPbPr) will then correctly recognise the signal from PS2.
Hope this helps you. I am also a 1920ex user.
Apr 16, 2008 | Sony PlayStation 2 Slimline Console
Ps2
You A/V cable or connector on the back of the PS2 has a problem. Inspect both closely to see if one of the connections is bent or peeled back. Check the housings of both connectors to see if the fit is comprimised.
Nov 21, 2007 | Sony PlayStation 2 (PS2) Console
Proview PL482S 14 in. Flat Panel LCD Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
