Question about Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer - spinning problem
It didn't begin as a spinning problem. Originally it was a coin that had plugged the machine. I removed the front, disconnected the hoses found the coin and re-installed everything. The problem is apparently there are at least 2 yellow cylindrical foam pieces that somehow guide the drum when spinning. One is located in the right and side of the washer. This one has a electrical wiring probably to hold it in place that goes through the center and sits against the drum and the inside wall of the washer . The other fell out of place. I'm not sure where the other one sits, but without it the washer makes a lot of noice when spinning and the drum jumps around quite a bit. I believe that if I could get a picture of the washers inside then I could locate where the other part is located and put it back in place.
  • Anonymous Nov 17, 2007
    won't finish drain and spin
  • tamzah Mar 01, 2008
    I have pretty much the same problems but mine also gives a code of F1 and it adds the word sud Anybody have any ideas?
  • 156 Answers
Go to parts put in model no. and it will show you views of the parts and you can also order new dampner shocks from there
Posted on Feb 28, 2008
My Kenmore HE2 plus front load washer is showing an error code and now it wont spin or unlock what is wrong with it
Your pump is blocked.prob a hair bobble coin etc... try the pump access at bottom of machine water will come out so u need to open it slowly
Jun 03, 2016 | Kenmore HE2 Plus Front Load Washer
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
I have a Kenmore front load washer that will not spin all the water out of the clothes. After it finishes I have to run it through a rinse spin cycle and it does fine. The machine is only 14 months old
The first thing to check is probably the filter at the bottom of the machine. I'm not sure about this particular model, but the usual thing to do is to remove the machine's front lower panel - i.e. the panel at the front of the machine, closest to the floor.
You will probably find a little drawer or door, just a couple on inches in size. If you open it, you may find some lint, a couple of elastic bands, and enough coins to buy a beer. If so, it's the coins that are causing the problem! Take out all the stuff, close the little door, put the panel back on, and everything should run fine.
I hope that helps. Good luck!
Oct 09, 2010 | Kenmore 44042 Front Load Washer
Coin or other object below the tub. You can hear it when this front loader spins
try to take the waste pipe off on the drum and tip your washer forward and see if you can see any thing
Jun 24, 2009 | Kenmore Elite 45986 Front Load Washer
Spinning to slow closes still wet
Hi, how are you?
I'm guessing you have a clogged pump and is preventing the machine to go into the final spin cycle. It's very common with these frontloaders.
You just need to take the bottom plate off (3 screws on the bottom) and open the coin trap and clean it out. It should be right in the front. Try that and let me know what happens.
Jun 01, 2009 | Kenmore HE2 Plus Front Load Washer
Kanmore 41042 Front Load Washer draining/ Spinning problem
do you hear anything like hair clip or coin,,i would check my pump first...onthejob
Jan 10, 2009 | Kenmore Washing Machines
Spin cycle noise
coins inbetween bowl can be a problem
try tacking machine outside empty of all water
tip upside down sometimes gets the coins out
otherwise you need to pull machine apart
try another way
remove from bellows from machine and turn bowl by hand to remove coins
have fun
Jan 05, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Oct 27, 2007 | Kenmore 44102 Front Load Washer
Kenmore front load tumble action washer
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. back.
Sep 23, 2006 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
118 people viewed this question
Sal De
 Brian Main
Brian Main
