Garmin Nuvi 200 205 250 255 260 W Logo
A
Anonymous Posted on Aug 02, 2014
I have a garmin nuvi 205 I cannot get voice instructions help
Kenny Rasmussen
Level 2:
Habit-Forming:
  • Garmin Expert 184 Answers
  • Posted on Aug 05, 2014
Kenny Rasmussen
Garmin Expert
Level 2:
Habit-Forming:
Answers
184
Questions
0
Helped
28863
Points
316
Under Garmin Express, click Device,
click optional updates
click voices
check mark english
go to the bottom and add to device
this should get you all set
5 Related Answers
Anonymous
  • 5158 Answers
  • Posted on Feb 02, 2009
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
Anonymous
  • Posted on Feb 13, 2009
SOURCE: nuvi 205 voice stopped working
I had the same problem. I went onto Garmin.com and attached the Nuvi to the computer using a cord that I had for my blackberry phone. Once connected, I turned on the Nuvi and ran the update tool. The update tool will reinstall the voices. This seemed to work the first time. I have had to do this twice now since I received the Nuvi 205 on December 26, 2008 (it's February 13, 2009)
Anonymous
  • 318 Answers
  • Posted on Mar 19, 2009
SOURCE: My Garmin nuvi 205 will not give voice prompt
The germin nuvi 205 can be pre loaded specific data on the route and has voice. i dont know if yours has been pre loaded, with 3.5 navigation data.
superdave1
  • 156 Answers
  • Posted on Jul 06, 2009
SOURCE: Remove a map to make space on my garmin nuvi 205
I would reset the whole unit to factory specs & then load map.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 27, 2009
SOURCE: My garmin nuvi 205 no longer has voice.
sounds like the driver for the speaker circuit is defective, call Garmin, since it is only one year old they may repair it for free to protect there good name, I assume u don't have the speaker turned off, this can be checked by going into the tool symbol and selecting sound volume.
.garmin nuvi 1100 voice will
if you are still getting sound when you press on the screen then the voice might have just been turned off, turn the unit on and hit tools>settings>language and the voice should say american english jack or jill
Does the garmin 205 say street names
Yes the nuvi 205 should say street names make sure that you have selected a voice with a TTS behind it. to this go to Tools > Settings > Language > Voice makes sure that you have something like "American English Jill TTS " or even "American English Jill".
Hope this helps!
Just bought a 205 and get no voice or sounds whatsoever
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Garmin Nuvi 205w and now it wont turn on.
You can restore the Nuvi 205 system software to its factory condition by running Garmin's WebUpdater service. You may also want to try a hard reset of your Nuvi.
I hope that helps.
My Garmin nuvi 205 has stopped talking. Is this fixable? Thanks for the help.
You have actidenttly muted your voice. You hit the menu button, and hit on volume. There is a check box next to the mute, uncheck that check mark.
1helpful
My garmin nuvi 205 no longer has voice but it still beeps when I use the touch screen so the speaker works. What could be the problem? It is a year old and worked until yesterday. Everything else is fine.
2helpful
Nuvi 205 voice stopped working
Garmin nuvi 200w map update 2009
Delete all the vehicles and voices that you don't use as well.
Btw, beware that the "City Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" for nuvi 200/205 is BUSTED, it probably will not work (I just spent 2+hrs on the phone with garmin tech support to fix it.) Search these forums for "nuvi 205 no detailed maps" for more details.
Jun 17, 2008 • GPS
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
