Open printer door, and out the cartridge but problem too.
SOURCE: paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
SOURCE: HP 1020 Error Message
Had the same problem. Changed cartridge. Still didn't work. I suggest taking out cartridge and examining inside of printer carefully. I found a piece of balloon and a hair tie (aargh!, my kids). Works now.
Just wanted to post this as one more thing to check before junking the printer or spending money on HP support.
SOURCE: Error message coming up: The HP LaserJet 1020 has
send your printer for service. seems like, one or two sensors are malfunctioning.
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a
sensor flag mounted on the paper feed assembly behind tray 1 which has
a habit of either coming off or the spring which moves it back a forth
comes out of its holder. In any case it is one of the worst repairs you
have to do. Many items have to come off to get to it and getting that
flag and spring on correctly even with the instructions is difficult.
Usually what will happen is you get the 13.20.00 error on power up with
no motor movement and when you open and close the top cover, the motor
will move but the same error reappears. If you are lucky it is just a
case of a shred of paper blocking the sensor flag from moving and worst
case of the flag having come off. You will need the service manual and
check the removal and replacment section on the paper feed assembly and
play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you
have a nice day
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
SOURCE: the hp laserjet 1020 the
Open The printer Side Cover. Then Remove Back Plate Of Printer There is Senser On Back Side Check They Are moving or not there is spring in senser
