Question about Frigidaire Kitchen Ranges
Frigidaire Stove - bottom element burnt out. Replaced the element but the breaker would "pop" every time I turned it on. Removed the new bottom element and discovered one wire came off during the installation. Suspect it grounded out and was the cause of the breaker tripping. No signs of burning or damage on the wire so I connected the wire again, checked tightness and reinstalled. The element is working find now. Problem - now the oven cooling fan does not turn off. Could I have damaged a control module or the sensor that turns the coolilng fan on and off?
jsrock516
  • 5911 Answers
SOURCE: bottom element will not turn off
Your BAKE element relay on the Electronic Oven Control (EOC) Board is shorted.  I have experienced this problem before.  The board is not serviceable and (unfornately) you will have to replace it.  The board can run anywhere from $100 to $200 for a new one.  Slightly less for a refurbished one.  Prices will also vary depending on source.  This is a repair you can do yourself if you choose to do so.  If you can provide me with your model number (located inside the lower door panel), I can do some research to get a part number and price for you.  Let me know.  I hope this is helpful.
Posted on Oct 31, 2007
fridgetech
  • 473 Answers
SOURCE: FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Posted on Nov 12, 2007
Amigaman
  • 248 Answers
SOURCE: Top element in oven not working
This "top element" is your broil element. It will only get red when broil is selected.
Posted on Nov 20, 2007
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
SOURCE: frigidaire compact 30 elec. stove.
Does yours have the timer/clock thing that stands at the rear left of the stove? If so, make sure the far right dial is set at Manual. I had a repair person come out once (luckily it was someone I knew who didn't charge me) because my oven quit working. He turned the dial to manual and presto! :)
Posted on Dec 04, 2008
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
We have a free standing Frigidaire flat top stove oven that is electric I decided to use the self cleaning feature on it and the bottom element burnt into My husband removed the bottom element before...
I THINK THE HEATING ELEMENT YOU GOT COULD BE WRONG SIZE. I KNOW MINE WENT OUT WHEN COOKING SOMETHING HOTTER THAN I USUALLY USE LIKE 450 DEGREES, IT BURNT OUT. BY CLEANING OUT YOU'RE OVEN, WHICH REQUIRES REAL HOT TEMPERATURES, IT SOUNDS LIKE YOU ON THE RIGHT TRACK. IT BEING OLDER STOVE, A LOWER RATED ELEMENT I WOULD TRY..
Mar 24, 2017 | Kitchen Ranges
Loud pop from Range, stove top still works
The pop was a shorted wire.
The short drew sudden over-amp at breaker.
Amps = heat.
Breaker senses heat and trips before wire to oven is damaged, and before the arcing short can cause a fire.
Was the short at the element?
I don't know, but sounds like the circuit board was damaged.
Of course they are putting electronics inside all appliances today instead of old mechanical dial, because it's cheaper or so much prettier... but new appliances more vulnerable to surge, and other electrical failures. Which is true for all 240V appliances not protected by whole house surge protector.
To test element.
Remove element.
Use a continuity tester across the element connections.
If there is continuity, then the element is probably functional.
Use a multimeter across same element, set multimeter to read ohms.
240 Volt, 3500 watt element should be about 16 ohms.
4500 watt about 12-13 ohms
Volts squared divided by watts = ohms
57,600 divided by 4500 watt = 12.8 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
I would guess that the short fried the circuit board, but there is a also a shorted wire somewhere that is still bare and dangerous while power is ON and you are touching oven or stove, unless 240V breaker is GFCI or arc fault, which probably not. Especially dangerous if you are moving stuff around trying to find problem while power is ON.
Gene
h
Nov 19, 2013 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
I have a frigidaire oven, my wife touched the oven element with an oven mitt and blew out the main 100 amp house breaker. the oven does not work anymore but the burners are fine. should i buy a new element...
THE ELEMENT SOUNDS LIKE IT IS SHORTED BIG TIME TO TRIP 100 AMP BREAKER. I CAN'T SEE WHY A ELEMENT BEING TOUCHED WOULD DO THAT. CHECK THE WIREING TO THE ELEMENT AND MAKE SURE NOTHING ELSE HAS SHORTED TO ALSO CAUSE THIS PROBLEM, PLEASE TURN THE POWER OFF FIRST. BUT THE ELEMENT CAN BE REPLACED AND NOT THE WHOLE STOVE
Aug 28, 2009 | Frigidaire Ovens
Stove cutoff after loud popping sound
The element burnt in to and arced which is the loud noice you heard red flash of light. It probably tripped the breaker at the electrical panel. Don't turn it back on until someone checks the element and replaces it.
May 28, 2009 | Kitchen Ranges
Replaced bake unit in Frigidaire FEF366DCA yesterday and when I turned on to bake @ 350 I heard a "pop" and the oven would not heat past 300 in quite some amount of time. Is it a blown fuse? And if so...
the pop is most likely an electrical short it will be in the back of the stove,that is unless your new element shorted .when cool you can run your hand around it and you should feel no blisters,smooth only.other wise you are doing a visiual inspection and looking for an obivous burnt wire/connection.God bless ,tom
Jan 04, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire electric smoothtop range no longer working...
it sounds like a wire from the bottom element in the oven shorted.check the circuit breakers to see if there tripped,if so reset it and try the oven,let me know.
Dec 29, 2007 | Frigidaire FEF366 Electric Kitchen Range
Kitchen Ranges Logo
212 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
