I'm installing a new printhead from KODAC Inkjet Printer for no cost
  • Manish Raj Gupta May 11, 2010
    u havent mentioned the problem that u r facing.
  • 916 Answers
There is no way to replace a print head for no cost. The print head needs to be bought at the very least. As for having someone else do it, it can be cheaper to just replace the printer.
Posted on Sep 07, 2009
Printer message says printhead not installed correctly or has come loose. I have removed it several times but it still has same message.
REMOVE PRINTHEAD AND ATTACH IT REPLACE WITH NEW ONE IF NOT WORKING.. SOMETIMES ITS TOO MUCH COST FOR PARTS FOR INKJET PRINTERS ITS NOT WORTH FIXING IT
Jun 22, 2017 | PRINTER Office Equipment & Supplies
B200
A new print head would not be cost effective. For the price of a printhead you could replace your printer.
Jan 21, 2014 | Canon IX6550 A3 Inkjet Printer Inkjet...
HP 6940 won't print black-new cartridge installed-prints color but no black
In all likelihood your print head has become clogged at the black ink outlet. Be aware that printheads can BURN OUT if you keep trying to print and there's insufficient ink reaching the printhead. The ink flow is relied upon to prevent overheating of the tiny resistors at the printhead. Best bet is to remove the cartridges from the printhead and then remove the printhead and try to clean it in warm water. You will find many youtube videos on suggestions for cleaning the printheads on HP printers. Do a google search for your model. If all else fails you can order replacement printheads for the part that has failed. They are not cheap so price compare. Oftentimes they will cost nearly as much as a new printer!
May 16, 2012 | HP 6940 InkJet Printer
I have deep cleaned my MP190 twice as per instructions and still I get horizontal lines in my printing.
The printhead has a few blocked nozzels. If deep cleaning does not clear the blocked nozzels then the printhead needs to be changed.
A new printhead is an expensive item and costs nearly as much as a new printer. I suggest you put your money towards a new and better printer that may be a more cost effective solution.
May 09, 2012 | Canon PIXMA MP190 All-In-One InkJet...
We want to buy hp designjet 110 plus printer head were 2 buy and what its actual price?
I suggest you use Google to search for this model printhead on the Internet to get a price comparison from various suppliers.
You may find inkjet printheads expensive and it may be better to get a new and better printer for not much more than the cost fo a new printhead.
Jun 13, 2011 | HP Designjet 110plus nr InkJet Printer
Without realizing my mistake, I erroneously installed #3e Y-M-C ink cartridges instead of the correct #6 cartridges in my MP780. It worked fine for several days, then I got a message saying the printhead...
The fact is when you compare the cost to get a new printer to replacing your printhead and cartridges you find you may want to go for a new printer instead. The difference usually is not be worth it.
Good luck & God bless!
Nov 30, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Just installed new printhead and new black and colored ink cartridges. I do not have a calibration calibration sheet any longer. This is for Kodak easyshare 5300 printer.RAU
When you install new printhead in the printer, you will get a message" New printhead detected ,load papers in paper tray and press start. If u do not get this message,that means you have not installed printhead properly. Visit www.kodak.com/go/printheadsupport and click on 3 rd link installing or replacing a printhead to see how to install printhead correctly
Dec 03, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer kodac esp 3 doesn't want to print in black
Clean the Printhead
Reseat the Inks
Reseat the Printhead ( to remove the printhead go to www.kodak.com/go/printheadsupport)
If the above did not resolve the problem
call the Technical support they will replace the Printhead
the number is 1800 421 6699
Hope this will help
Regards
Byron
Aug 20, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
No colour
Hi!
Mostly it's a problem with the printhead in those case.
Try 4-5 printhead cleaning via the main menu of your printer. Press Menu. Choose 'Clean Printhead', press OK and chose the 'Intensive Cleaning' and press then OK again.
After doing this 4-5 times make a test print. When the problem persists, you can order a new PH from Kodak directly.
Aug 09, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
It sounds like you have a bad contact between the printhead and the printer. First remove the inktanks. then remove the printhead. Now re-insert the printhead and remove it - do this a few times. What this is doing is scraping off anything that is blocking the full contact between the printhead and the printer. It should only need to be re-inserted like 3-5 times. Then leave the printhead in and install the inktanks and print again. If this does not work call Kodak and request a replacement printhead (they should not charge you its not your fault this is happening) or return the unit to where you purchaced it and ask for a new one. Once you get rid of the problem you will like the printer they do print great quality photos for such a low cost ink.
Feb 13, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
