My key goes in the keyhole but it won't turn. The trunk release button is usually what i used to open the trunk but it quit working first. I was able to use my keys to open it for a few days now it doesn't work either. Please help
SOURCE: Car Chimes in 2002 Chevrolet Monte Carlo saying trunk open when it's not can it be turned off?
I would check around the area on the trunk for a switch and bypass it rather than unhook it but be careful dome light switch is there too. You can just follow the sound and unplug the chime tho
God Bless Greg
SOURCE: starter continues turning after I release the key.87 monte carlo
Hi, Check and make sure the starter relay is not sticking. If it is not, then the bendix in the starter is probably bad or not shimmed properly. You can check the starter when you remove it, be careful of the torque. Good Luck to you. Hope this Fixsya!
SOURCE: I have an 06 impala and the TRUNK WON'T OPEN. It
you have a fuse for it ,check the fuse box ,it might not say trunk on fuse panel, you might need to pull those fuses out one by one checking each one to see if blown, if the center between the two sides are broke the fuse is blown, hope this helps you, thanks robert b.
SOURCE: Chevy Malibu Trunk Problem
i have a 2005 chevy malibu and i close the trunk with the keys inside and the little button on the door is stock but the car is open is and other way to open the trunk from inside of the car?
SOURCE: 2002 monte carlo fuel gauge doesnt work,pump works ok.
It is likely the fuel level sending unit. I had a customer with an 03 Monte Carlo that the pump went out and the fuel gauge hadn't worked in about a year. We replaced the fuel pump module and it took care of both problems. I believe the sending unit is available separately from the complete module.
Testimonial: "Works Perfect Now:::Thnks"
