Question about Kenmore Elite 45986 Front Load Washer
Where is the lint trap on a kenmore mod.110 13212200 ser. CM2110993 washing machine? is it easily removed? or will i need to call a tech? tks in advance A.F
  • 15,935 Answers
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
How to remove Control Locked
www.appliancerepair.net/kenmore-washing-machine-repair.html
Jul 27, 2014 | Kenmore Elite 45986 Front Load Washer
Top load washer Inglis mod.im45000,ser.cp4304291 smelly, cleaned lint trap,inside of tub,put baking soda in,
Spray a stream of bleach-type cleaning solution (Clorox Clean-up, or bleach and water mix) between the inner and outer tub at the top rim. Run a soak cycle with water and bleach (full load water level setting). I haven't looked at the manual for your washer, so if it doesn't have a soak cycle, start a normal cycle, stop it after a minute of agitation, then let the washer sit for at least an hour before starting it again.
Sometimes the particle traps at the water inlets get a bacterial film growing on them. Turn off the water to the machine, remove the hoses and clean off the trap screens. If there is a film, put the hoses in a bucket and turn the water on to flush them out. This will help prevent the return of the odor.
May 30, 2011 | Washing Machines
Is there a lint trap or lint filter on this washer? It is a kenmore washer model# 11022622100. I seem to remember my old washer having one inside the lip of the tub but I can not find one anywhere.
On most 110 mods there was what they called a lint trap at the bottom of the wash basket.You can;t see it without taking the basket out (ya I know dum) you will need special tool to remove basket.that filter has now been replaced by whirlpool with 4 little plugs and the so called filter is removed.You can clean the old one and unit will be fine..for that job I would say to get a pro as it takes me about 2 mins to open and will save you as a home owner a whole lot of headaches..Hope I helped and Thanks for voting
Just a note that whirlpool made that machine.
Mar 17, 2011 | Washing Machines
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Kenmore 90 Series Washing Machine. Does it have a filter that needs to be cleaned regularly. I owned a maytag previously. It had a center post that collected lint etc. that needed to be cleaned. I...
It's an auto-clean internal lint filter. Lint is trapped from water circulating through the filter during the wash cycle. During the drain cycle it's backwashed and the lint goes down the drain.
Feb 02, 2018 | Kenmore Washing Machines
Kenmore 100 washer leaves tons of lint
Remove the hoses from the pump. The lint trap will be there.
Jun 16, 2009 | Kenmore 22422 Top Load Washer
Lint trap
First you need to remove three screws on the front lower panel. This will expose a round "plug" to your right. This is the lint/drain trap. Place a bucket under the plug. Slowly unscrew this plug and aloow the water to drop into the bucket. Make sure your plug is clean and reset it.
Jun 10, 2009 | Kenmore HE2 Plus Front Load Washer
Washer Kenmore 90 Series
yes it has a lint trapped ..its on the bottom of wash basket,,its part of the wash basket..when the unit washes it traps the lint when the unit goes in to spin it shoots it down the drain,,i dont advice taking that out unless your a tech..now what you can do is fill unit with hot water and about a pint of bleach and let that do the work its also good for pipes,,this technic should have been a process 1 amonth ..
Dec 22, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
159 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
