Suspension legs for hotpoint WF740P
I suspect that the suspension legs on my hotpoint wf740p washing machine are shot (there appears to be oil/grease coming out of them) as the drum seems very loose. There appears to be at least 3 different part numbers for the suspension legs. Are the 2 legs the same and which P/N do I require.
    Sergeant:
    Champion:
  • 353 Answers
Change all 3 legs together quote model no.of machine
Posted on Jun 30, 2009
Getting f08 error on my hotpoint wf740p
Call Hot point and ask them what an f08 error is, or check the booklet that came with your washer-they usually have a list of common errors.
Nov 22, 2012 | Washing Machines
Hotpoint wd440 washer dryer. Noisy when spinning and rumbling noise when washing.. Could thus be bearing?
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 12, 2012 | Hotpoint Washing Machines
How do I change suspension legs on Hotpoint WMA 62? The drum on my Hotpoint WMA 62 is bouncing around really badly on fast spin which disconnects an electrical connector turning the machine off. Both the...
Could be worn or broken dampers, or loose concrete balance weight.
This would cause the problem you describe.
There are 2 wieghts, one in the top, and one at the bottom of washer.
Check that the nylon locating pins are securly fixed in the damper legs, as sometimes they have been known to come out of socket.
Mar 22, 2010 | Washing Machines
Vibration on 1400 spin
If it does it with no clothes in then :
Drum Loose, Suspension leg shot
Inner drum out of shape
Feb 28, 2010 | LG WM2277H Front Load Washer
Front suspension squeaks
if you could access on the suspected joints of the suspension, try placing some lubricant on it, drip some oil or grease to it!
Feb 16, 2010 | 1998 Ford Explorer
Out of balance how do I fix it maytag washing machine model 9457AAE
Only two options are there in it one is upper holding spring & lower suspension problem kindly check whether the suspension two legs will be there both are evenly moving otherwise replace the two legs which is not working fine then go for the upper spring if you found the upper spring problem replace the upper springs
Dec 24, 2009 | Washing Machines
How do you remove drum springs on a hotpoint WMA washing machine
working from the front using mole grips get hold of the suspension peg now feel round the back you should feel a raised part of the peg this has to be depressed now pull the peg out if it gets stuck push back 5mm and try again repeat on other side life the springs out with the drum
hope that helps
May 13, 2009 | Hotpoint WMA64 Front Load Washer
REMOVAL OF BLOCKED PUMP ON WASHING MACHINE
Remove the lower portion of the front panel. 3 screws.
Twist the pump filter and pull to remove it.
Mar 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD62 W/D. Works OK empty but bangs when full
Sure easily. Plug off the wall, open up behind to check if any springs have come off, check the shockabsorber, bolts.
Feb 11, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
187 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
