Question about MSI 661FM3-V Motherboard
I am tring to install win XP with sata drive and
I am tring to install win XP with sata drive and setup is not finding the drive
  • 4 Answers
Set 2nd boot item in CMOS to SCSI and during XP install, press F6 for additional driver. A floppy is then required with the WinXP SIS RAID/IDE Controller drivers.
Len
Duraltronics
Posted on Aug 04, 2009
  • 22 Answers
Make sure it is listed in your system CMOS before starting the XP install. Make sure cables are correct, and the drives are not turned off in CMOS. Some setup will allow you to set the drive types to AUTO, so you can also try that.
Posted on Jun 30, 2009
I want to install Windows XP on Sony Vaio VGN CS15GN B instead of Windows Vista but it is not happening kindly help
---------------> Perform a clean install of Windows XP 1)- Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
2)- When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
3)- At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4)- Read the Microsoft Software License Terms, and then press F8.
5)- Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
6)- Follow the instructions on the screen to complete the Windows XP Setup.
Note:- Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
May 25, 2011 | Computers & Internet
When i start win xp setup from wintousb software bcz i want to install win by usb after loading win files it gives blue death screen technical info:...
try going into the system setup or bios screen and see if you can find a setting for SATA Operation or SATA Mode for the hard drive. if you can find this, select ATA or AHCI and test the installation again. hope this helps.
Apr 16, 2011 | Computers & Internet
Hello my dear i want install 1 hard disk 320 gb and after that install win xp on my qosmio but after start setup win xp show mw did not find hard drive. how can i repair this problem? thanks
In order to be detected the hard disk drive by your windows xp installer. You have to set your sata in your cmos or bios setup. When powering your computer tap the F2 key or Del to enter cmos or bios setup, go to integrated peripherals and look for the sata controllers. Most of the times if its configured as a enhanced the windows xp can not detect it. You have to change the settings to compatible mode. Please the modify key either F5 or F6 or PGUP/PGDOWN or + or - . After changing the settings press F10 and press y and enter. Then try again running the windows setup. Have a nice day.
Feb 17, 2011 | Toshiba Qosmio G35-AV600 Notebook
Hello, Where could I find a driver for WD5000KS SATA? I am trying to upgrade my desktop PC to Win 7 but when installing it, the setup could not detect the SATA HDD and asked me to load the HDD driver. ...
Check in your BIOS,first make sure the SATA controller is set to native mode and not RAID, and secondly that the BIOS can detect the drive, if the drive can't be detected by the BIOS then it's because the drive surpasses the boards drive size limitation.; If this is the case there is a chance a BIOS update may fix it but it's not guaranteed it will.
Jan 05, 2011 | Western Digital Caviar SE16 (WD5000KS)...
I want istall win xp o/s so i need to change bios setup to detect the hardisk drive. how can i change bios srtup?
Here is what you need to do to install XP on your laptop that came with Vista or Win 7.
If your hard drive is SATA (pretty much standard these days) you will need to search the manufacturer's site for a floppy disk SATA driver install package.* You will need a USB floppy drive for installing XP.
* Copy the SATA drivers (should be denoted as "F6 drivers" or similar) to a blank disk.
* Have the USB drive connected. It should automatically map as A:\.
* Go into BIOS and find a setting for ACPI Compatible and set on.
* Now install XP normally from the CDROM, and when it says "press F6 to install third-party drivers", press F6 and follow the options to get the SATA drivers from the disk.
* Complete setup as normal.
or
You can check the following link for more detailed info.
Thanks !!
Please rate the solution if it helps you.
Nov 23, 2010 | HP Compaq nc6220 Notebook
Displays no hard drive found wen installing win xp
You have to go to BIOS setup, find HDD setup, and change the value to the other one (there are only two possibilities). That will fix your problem. The problem is caused by the fact that the lap top was designed for vista, not XP. and the lap top contains SATA HDD. when installing XP pre-installation doesn't have SATA drivers, so your OS can not see the HDD. Change it in BIOS, and you trouble is gone
Nov 14, 2009 | Toshiba Satellite A200-19501F Notebook
How can i desable sata hard drive in laptop for installing win XP
in the BIOS you should change the following option
sata native mode should be disable.
Feb 02, 2009 | HP Pavilion dv2000t Notebook
Non detection of hard disk in dell laptop while installation of win xp sp2
I haven't heard of not being able to delete a partition before. You could go to the manufacturer of the hard drives website and find the software to do a low level format or you could download a linux distribution and use the installer to remove the ESIA partition.
I would need to know the model of hard drive and laptop if you need any further assistance.
Sep 08, 2008 | Computers & Internet
Xp wont load
go to BIOS setup check that sata is recognized also if you have an ide drive in computer it may not find the one to use I had to remove ide drive for windows to install
Aug 09, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
MSI 661FM3-V Motherboard Logo
355 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
