Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
No power to in sink erator; washrage chewed up
Where is red button on in sink erator? If a washrag was stuck in it, but entirely chewed up and no pieces to get hold up to pull out, what is the solution:? Initially, did not realize washrag was stuck. Turned disposal on; worked fine for a few seconds, then completely shut down. No noise, go grinding, no power. NOTHING. Later it was discovered a washrag was taken in, but after pulling out a few chewed ends, there was nothing to grab hold to.
  • 63 Answers
Sometimes Maufactors Put The Reset Button In The Far Bottom Of The Unit If You Find Button Some Do Not Have One on Them You May Check And See If It Is Wired on Its Own Curcuit It May Have tripped The Beaker In The Main House Service Panel
Posted on Jul 16, 2009
In-sink-erator
I think it's time to replace the whole garbage disposal with a new one!!
Jan 21, 2014 | Home
1 thinks its wet , 1 sparks and snaps.
I took the blades and a washrag in the shower with me and cleaned them. Then I put them in front of the air vent for 8-10 hours. Then I put them back in the unit. Sparking and snapping could be from dirt moving through the unit.
Nov 21, 2013 | Sharper Image Hybrid GP Germicidal Air...
Dryer turns off. screen reads e68
Stuck button on keypad. Get a wet washrag as hot as you can and go over the keypad.
Jul 06, 2012 | Frigidaire Dryers
Keynboard, types, exztra, letters
Useually that means that something was spilled on it. the best way with the acer keybord to solve that, provided it is the case, is to gently pop the keys off with a butter knife or thin but long bit flat head screwdriver. Then once all the keys are off, take a moist, but not too wet, washrag or towel and gently wipe the offending material from the key mounts and button pressure ports. (*note* do not use paper towels, it will leave debries as the cleaning progresses...) once finished, let it dry completly and replace the keys. If that does not solve it, then it is most likely in need of replacement.
Hope this helps =)
Feb 21, 2011 | Acer NSK8458AN Keyboard
My washing smells bad
Water maybe stale and mold maybe building inside the seal for the door. Use bleach water and a washrag and clean the seal and run a just bleach and soap load through the washer on its hottest setting to kill anything you can reach or wipe down. Do this whenever you feel its not clean to your standards.
Apr 17, 2010 | LG WM-3677HW Front Load Washer / Dryer
Frigidaire side-by-side ice maker hose froze up
I've seen three solutions to this but havn't tried them yet. One was to gently turn the tube counter clock wise to separate it from the refrigerator and then clear the ice form the end of it another was to use a hair dryer to thaw it out and the third was to wrap warm washrags around it to thaw it out.
Jun 15, 2009 | Frigidaire FRS3R5EMB Side by Side...
Jammed disposal (in sink erator) i believe a nail was lodged there. it came out but it still doesn't work. Had a allens wrench and hit red button and it still doesn't work
My unit was not spinning, seemed like no power after it would just sit there and make that humming noise. Used the wrench to loosen up (if any) debris. I didn't realize the little red reset switch on the bottom was not popping out all the way. After the wrench, I then depressed the red button and it worked fine. I would check to make sure your switch is out all the way before trying other solutions.
Jul 04, 2008 | Dishwashers
Noisy
I had the same problem with mine. The only solution we could come up with was to place a small towel/washrag underneath it, and wedge it into something if you can. This solved our problem.
Sep 29, 2007 | Wave Industries OLY-OL3000 Globe Phone
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
287 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
