The A/C unit is just humming could it be the capacitor
  • 8,220 Answers
Take a look at the capacitor. If it is swollen, rusty, puffed up on top, or leaking it is bad. Sometimes you cannot tell by looking at it so you can test it. Using a suicide cord attach the aligator clips to the capacitor, Place the cap where if it explodes it's remains won't get on you.
TIP: (check to see if the leads are shorted to avoid any minor explosions.) Plug the cord into a 120 volt outlet for 3 seconds. This charges the cap. Tap the cap on an iron surface to discharge it. If it makes a popping sound it is good. If it does not hold a charge it is bad. Another way is to check it with an analog meter. Set the meter on the most sensitive setting. Touch the leads to the discharged cap. The needle on the meter should hop; reverse the leads and retry it should hop again. That is an indication of a cap that will hold a charge. If the needle never moves of course that is a sign the cap is bad. Also if the needle goes all the way over and stays, that is an indication the cap is shorted and therefore bad. The cap is designed to boost the power to the motor to get it going with multiple windings being powered up at once. As soon as the motor reaches running speed the cap drops out of the circuit and it takes half the power for the motor to continue running at optimum speed. This saves energy.
FYI: The old style shaded pole motors had no capacitor and so they used twice the power to do the same job.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 30, 2009
Outside unit comes on. inside unit stays humming
You could have a bad motor or motor capacitor. The capacitor is the can with two or three wires coming from it. Shut off the power to the unit and remove the blower panel. Check to see if the motor turns free and is not noisy. Next see if the motor is hot after it has been humming; if it is it may just a new capacitor and they are cheap and can be picked up at ac supply house. I'm going off the info you provided. humming can sometimes just be the transformer and you could have a blower relay issue. I have provided the most common issue that I find with this description.
Jul 31, 2012 | Goodman Heating & Cooling
Goodman model CLJ30-1D humming but not cooling? Help it's 9pm and 100 degrees outside
Hello, so both the fan and compressor were not running? Sound like the capacitor is bad, usually when the temp gets that hot the capacitor overheats and goes bad. The capacitor is located in the outdoor unit inside the control panel, it looks like a round or oval can with wires connected to it.
Jun 27, 2012 | Goodman Heating & Cooling
CKJ-361A GOODMAN CONDENCER UNIT (13 YEARS OLD): RESET INSIDE BREAKER, WENT TO UNIT, NO SPIN-HUM ONLY, GAVE FAN BLADE A COUPLE OF SPINS=STARTED WORKING, RAN FOR APPX. 30-45 MIN, STOPPED, TRIED BLADE...
Replace the capacitor inside the control panel on the outside unit. The top of the capacitor may be puffed up.
The fan motor may also be going bad. Change the capacitor first. It will have to be changed anyway if the motor is bad.
Aug 21, 2011 | Heating & Cooling
Tech 2000 just quit. The problem is the outside unit. I cannot get it to start when I manually push the contactor. No fan and no compressor. Unit just hums for a couple of seconds and then no hum. ...
Sounds like a shorted capacitor. THe capacitor is located right beside the contactor. Looks sort of like a batter. Probably has 3 posts on top. If its shorted it usually will look pregnant or swollen. A capacitor is not very expensive. You can get one at any air cond supply house.
Jul 13, 2011 | Carrier 38CKC042 Air Conditioner
Toilet will not work. when plugged it it hums even if i dont push the button,
When the unit is humming it could be something stuck on the blade or impeller preventing it from spinning. The drain pipe can be clogged or the capacitor which drives the blade and impeller may have gone bad. Tipically when the capacitor goes bad it will just hum and not pump the waste out.
Aug 21, 2010 | Saniflo & Saniplus& Macerator Pump
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
It just humms nothing clogged on blades, whats up?
Typically the pump will hum is something is stuck on the blade, impeller or if there is a clog on the drain pipe that is not allowing the waste to be pumped out. The capacitor/condenser drives the blade and impeller, if the capacitor has gone bad it will make the unit hum and not pump the waste out. If there are no obstructions then most likely the capacitor will need to be replaced.
Mar 23, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Power on unit hums but does nothing else just keeps humming?
hi there,
stuck up motor,could be capacitor check this out and replace.
could be relay.if defective replace.the motor has star winding after replacing capacitor and humming again,check start winding,if high resistance,replace motor.have a good day,rate me if your satified to my suggestion,thank's a lot
Apr 28, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
