Question about Marathon DJ-2000 Amplifier
Both clip led light stay on and amplifier is switched on
This item is brand new out of the box. There are no input our output connections connected to it. I just took out of the box connected the power chord and switched it on. The clip led red lights just stay on. Have not tested if it works otherwise as I fear that it may damage the speakers.
  • 4,234 Answers
If the clip lights are on the unit has detected too high an input level. With nothing connected, this indicates a problem in the pre-amp section. Since this happened right out of the box, don't waste time on it. Return this for a warranty exchange.
Dan
Posted on Jun 30, 2009
My amps stays in the clip mode where as the light on the two channel stays red
http://www.retrevo.com/support/QSC-RMX-4050HD-Amps-manual/id/23107ci658/t/2/
Page 7...
CLIP: red, to the left of each Gain control.
Normal indication: illuminates whenever the amplifier is driven beyond full power. The LED's brightness indicates the amount of distortion. Distortion that causes only brief flashing may not be audible.
During muting, the indicator fully illuminates. This occurs during normal "On-Off" muting.
Abnormal indication:
•Bright red illumination while the amp is being used indicates either thermal muting or a shorted output.
•If the amplifier overheats, the fan will run at full speed, and operation should resume within one minute. Allow the fan to run, and make sure the amplifier ventilation is adequate.
•A shorted or overloaded output circuit will cause excessive Clip flashing and possible overheating.
•If distortion is audible without a Clip indication, the problem is either before or after the amplifier. Check for damaged speakers or overloaded signal source. The amplifier Gain control should be in the upper half of its range to prevent input overload.
Jan 29, 2011 | QSC RMX 4050HD 2Channel Amplifier
How do u know if A sony xplode XM-552ZR amp is on and how do u connect it to a sony xplode cdx-gt570 head unit.
Just to the left of the output (speaker) terminals, near the top of the amp, there's an LED marked "POWER/PROTECTOR". If the amp is connected properly and powered on, the LED is ON.
If the amp is being used for normal speakers, use a pair of RCA cables and connect the left/right channels to the appropriate inputs on the amp. The switch marked "LPF" should be "OFF".
If the amp is being used with the channels bridged for a subwoofer, use an RCA "Y" adapter and connect the single "Sub Out" preamp output from the head unit to both amp inputs. The switch marked "LPF" should be "ON" and the crossover set to about 80-100Hz.
Nov 03, 2010 | Sony Z2X-1200 SPL Car Amplifier (1200...
Mixer volume LED's do not work
a circuit controls the LED meter. i dont think the LEDs are faulty. the LEDs are connected to this circuit (IC). changing the LEDs wont work.
Mar 14, 2010 | Audio Players & Recorders
My husband is looking for a user manual for a Terk s-video switch. He got the used item from someone at our church - but they had no documentation for it. Where can I get a user manual?
From my search results, the model number is Terk VS-4. You can view the user manual by clicking here. You need Adobe reader to view it.
More information is given below:
This unit allows you to feed up to 4 stereo audio and video sources to one unit (normally one television which has A/V inputs).
It also allows you to connect a second device such as a portable recorder or amplified loudspeakers to the front AUDIO only output (stereo minijack).
The two outputs are always live.
There are four switches on the top of the unit which allow you to select which of the four inputs you want to use.
Since this is a passive device (no AC or batteries) the input which you select is indicated by a red mark (non-illuminated) which appears when you select the input.
This unit is a perfect solution if you have a receiver or amplifier with no video switching or without enough video switching (or with no S-video capability).
...Placing the unit directly on top of a TV could cause electromagnetic interference. If this occurs simply move the cables and/or the switch box .
S-video signals will only be output when a corresponding S-video signal is connected to the input. For example, if you connect a standard VHS VCR to input 1 using composite video, only composite video (not S-video) will be output from Output #1.
Only output #1 should be used for dubbing or editing, since recording levels will drop if you use both Output #1 and Output #2 simultaneously."
Source
Dec 16, 2009 | Televison & Video
Connecting dvd player
You need to use a receiver and connect the units to the receiver input, Then connect the receiver output to your television's input circuit. This should allow to switch inputs to the television. This can also be done with a switching box that allows several input and output. This unit should be hooked up in the same manner with the outputs to the switch box inputs and the switch box out to the television's input circuit. the difference between the two methods is the receiver has a preamplifier that will increase weak signal levels. The switch box is a passive device and usually will not amplified the signal to the input device. You can buy amplified switch boxes if you need them. Hope this helps you with your problem.
Apr 26, 2009 | Insignia IS-PDVD10 Portable DVD Player
NO SOUND
I am also having a similar problem. I am using a classic 1985-87?? reciever. I dont want to give it up however, i blew a fuse after plugging in an input while the unit was turned on. The system light up and that was that. After replacing the required fuse correctly, everything turns back on. No sound output. no indication of sound off the needles either..
Oct 21, 2008 | Audio Players & Recorders
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
Behringer EP2500 no output on CHANNEL 1
check all op amps for correct voltage swing +-should be equal,test output of op amps no voltage should be present, use chasis gnd as tester neg.check voltage regulation especially 12v or 15v +-.note some amps show unequal led indications when only 1 channel connected to a load.I will try to get some more info on this specific amp because i don't know this circuit well,keep in touch as you update though.
Aug 21, 2007 | Behringer EUROPOWER EP2500 Amplifier
Cant get the red led light green again
Disconnect all input and output cables and check. If the light stays red, it suggests an internal error. If not, proceed by first connecting the Sub wires and checking, then the input RCA's and checking. Remember to switch off the system before connecting/disconnecting, I suggest also removing fuses during this process.
Mar 11, 2007 | Pioneer GM-232 Car Audio Amplifier
Marathon DJ-2000 Amplifier Logo
606 people viewed this question
Top Marathon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marathon Audio Player and Recorder Expert? Answer questions, earn points and help others
