Question about HP Pavilion dv8000z Notebook
Battery short life 30 minutes maximium
My battery fully charged shuts computer after maximuim of 20 minutes
  • 1,006 Answers
Re: battery short life 30 minutes maximium
Try this one:
If it wont help you so just buy new !
And rate this solution as SOLVED if u got help
Posted on Nov 08, 2007
0 characters
3 Points
How to charge your laptop battery properly? During the the process of notebook...
How to charge your laptop battery properly? solarroll-laptop-solar-charger.jpg During the the process of notebook using, we need no to deliberately charge the laptop battery to 100% state or fully discharged laptop battery to automatic shutdown protecting. The correct way is that charge the battery in 20% state and stop charging in 98% . If the machine has the power calibration procedure, when the battery standard-by time significantly reduced. Then calibrate the battery in time to active the protection circuit performance.
For early notebook batteries (Ni-MH Ni-MH or Ni-Cd Ni-Cd), really need to fully charge and discharge in order to maintain good battery capacity. But for the lithium battery is not necessary even it may damage the battery.
In fact the lithium batteries has a little memory effect. The lithium battery materials is very sensitive to the conditions as temperature, the use of frequency and so on. The battery will be aging after used for some period time (standby time reduced). The natural wear and tear is an important reason, and inadequate maintenance is another important reason.
A well-designed lithium batteries have a very good protection circuit to prevent excessive charge and discharge.As over-charging and discharging of the Sony VGP-BPS8 battery will be the rapid reduction activity. Under the protection of protection circuit, the user fully charge and discharge the battery several times, in fact, impossible to achieve had "full" level.
Sometimes WINDOWS show that battery capacity is 20% or more, you can use 30 minutes. But after used 10 minutes or less the machine suddenly automatically shut down. The reason is that the battery has been aging, the battery protection circuit can not monitors the battery real capacity. In the normal battery depletion, the protection circuit original parameters have been unable to properly reflect the actual situation of the battery
So power calibration procedure is to correct the benchmark protection circuit parameters to accurately reflect the actual capacity . This correction process will often take two or three complete charge and discharge. As previously mentioned, fully charge and discharge will reduce the battery activity. It is not frequently used, usually once a month.
on Jan 18, 2010 | PC Laptops
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? '
    Mar 13, 2011 | Acer PC Laptops
    My Acer 6920 Battery is not being read properly- It says it will only last 1 hour when fully charged in power save mode. However 6months ago [when originally bought] it was being read as 1 1/2 hours. Not...
    That is a known issue with that model of computer. The battery is not very good. I recommend taking it to a certified repair technician for an expanded battery.
    My cousin has one and using windows 7 he gets about 20 to 30 minutes of battery life on average.
    Jan 22, 2010 | Acer Aspire 6920 Notebook PC
    Battery meter is low, even though computer is always plugged in
    Hi, I recommend you to try refreshing your battery by doing this step for 3 -5 times 1.Make a fully charge it take around 10 Hours. 2.Unplug your adapter and use the battery until it fully finish.Off by itself. 3.Repeat step1-2 for 3-5 times and see it again
    Oct 07, 2009 | Acer Aspire 6920 Notebook PC
    Battery does not charge
    Will the old battery (that you are replacing) charge up at all? If the old battery charges but the new battery will not, then it's likely a bad replacement battery.
    To rule out the possibility of a corrupted battery meter inside of windows, you may wish to leave the laptop on battery power only, until it dies. A 5% charge will usually only grant you about 20 minutes of laptop life maximum. Since you left it charging all night, you should get a few hours of life before it dies. If you get a few hours of life, the battery meter software is corrupted.
    Most likely though, the replacement battery is bad.
    Sep 02, 2009 | HP Compaq Evo n610c Notebook
    Inspiron runs on ac power but not battery
    Sounds like you have a faulty ac adapter or jack on the laptop and its not charging the battery fully. More like a trickle charge. I would recommend leaving the laptop on default power settings or the best power settings and see if their is a differance in life or either shutdown the laptop and let it charge until the light shows fully charged.
    Jul 20, 2009 | Dell Inspiron 1501 Notebook
    Laptop will not power up.
    You have a bad battery. I had same problem before and i just replace my battery and it works fine again..
    Oct 09, 2008 | Gateway MX7118 Notebook
    Purchased new battery, now NOTEBOOK won't work on battery after full charge
    Better you first charge the battery for 16 to 17 hours and recheck the same. If problem persists, change the battery from where you bought it. that battery is faulty. And yes there is no need to install the battery from device manager. Just open the battery compartment and replace the battery with new one.
    Feb 13, 2008 | Toshiba Satellite A45-S250 Notebook
    HP Pavilion dv8000z Notebook Logo
    43 people viewed this question
    Top HP PC Laptops Experts
    Brian Sullivan
    Brian Sullivan
    Michael Thomas
    Michael Thomas
    Are you a HP PC Laptop Expert? Answer questions, earn points and help others
