Question about Maytag Neptune MDG5500AW Gas Dryer
I have a maytag mdg5500aw dryer that stopped heating up. I took the front panel off and started the dryer, the igniter glowed and the gas ignited but shut off later. What do I need to check and where do I find it. Thanks.
  • mulloyc Jun 30, 2009
    Thanks for the diagram, I will take a look when I get home from work.
    President:
  • 1,865 Answers
You have to use a multimeter to find which component has failed. Could be the flame sensor.
The following link shows a diagram of the parts and where they are.
http://www.apwagner.com/index.php?main_page=model_lookup&model_num=MDG5500AWQ&model_id=49862&diagram_id=322552
Posted on Jun 30, 2009
Sg7800 maytag dryer stopped giving heat
Sounds like burner not igniting. On front of dryer in the lower right there should be a gas valve/burner access panel. Usually you just have to pry out at bottom of panel & swing out and up to remove. This gives you access to valve coils and igniter. With panel removed set timer for heated dry and start dryer, observing first the igniter which should glow bright orange-red, then after a couple seconds you should hear a "Click" which is gas valve opening and a blue flame ignites for heat. If no glow is seen after a few seconds or at least a minute, igniter is bad, if it does glow and no click is heard from the gas valve, the coils (electro magnets) on the valve are bad, or the "Flame present" sensor is bad. Chances are it's either the coils or igniter.Try this on all heat settings, if you get heat at only one setting it might be in timer contacts, but not common. Again you can repair/replace both the igniter (usually just plugs into a receptical) and the coils (2 donut looking objects on the gas valve, replace both.) Access door may be on back if not on front, but normally their on lower right of front.
Feb 13, 2011 | Dryers
The dryer is spinning but no heat what so ever...help!
HELLO THERE
There's no heat If your dryer doesn't heat, check these: Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas will not stay lit.
sounds like a bad coil
they are on top of the gas valve
Jul 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
It runs but no there is no hot air
the first thing you want to make sure is that the igniter is working, remove the orfice on the front of the dryer, an start the dryer cycle, it should glow if it doesn't then you have a bad igniter, if the igniter glows an you have no heat (at all) you want to check the thermalfuse onthe dryer, check for continuity with a voltage tester it it beeps means is ok , if it doesn't pass current replace it,
if you get partial heat only then it would look into the coils, the 2 coils are inside on the front of the unit. coils are replace for the most when your dryer takes a longer cycle meaning it takes longer to dry or finishes an clothing still damp.
good luck.
May 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
NEPTUNE FRONT LOAD GAS DRYER
1st.Look for glow from the igniter,are you getting power to the igniter?If you are getting power,and its not glowing replace the igniter.If your not getting power to the igniter replace the thermal fuse.
Jun 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Gas burner doesnt ignite somtimes
time to replace your gas coils. those are the two round things on the gas valve. chances are the dryer ignites when first started but as the dryer heats up the coils fail and as it cools again the coils work again. make sure you replace both coils
Sep 19, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
341 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
