Question about Garmin 010-00468-00 GPS Map 76Cx Handheld/Portable System With Americas Detailed Base Map GPS Receiver
When I turn it on it lights up as if to start then fades off. It is not the batteries as I have a 12v plug it & it does the same thing.
  • 2 more comments
  • saxman861 Jun 30, 2009
    Where is the reset button. It will turn on then the screen fades to off.
    Is there a Guru out there that knows the Garmin 76Cx GPS handheld/
    I tried your solution of holding the keys to reset but all that happened is when i hit the power button it started then faded away.
    Please cancel my request as i no longer require your service at this time.
    Please cancel my credit card & confirm.
    Thank you
    saxman861
  • 1,555 Answers
Take a backup first
Below is something which you shall know about your Germin.
1. There is a thermometer inside your Garmin unit. The intent of this thermometer is to compensate the internal time-of-day clock for changes in temperature which will cause the internal crystal to drift. To a lesser extent it is also used to adjust the contrast of the display screen for temperature changes. It will not measure ambient temperature except when the unit is first turned on since the internal temperature is changed due to the heating effects of the electronics in the unit. The thermometer based correction works by building a table of correction values that are then applied to the internal clock. This is only used to obtain an initial fix since after the fix the satellite data is used to keep the clock accurate. Similarly while you have a fix the accurate clock can be used to update the temperature data in the table which means the unit will compensate for aging parts and even the complete loss of the table.
2. To completely reset on of this units hold the "menu" key and the "quit" key down and then press the "power on" key. Hold for a full 7 seconds and then release. As with the other units all information will be lost and you will need to reload the almanac and all your saved user data to make the unit usable. For the 76S try this sequence to master reset it. Press and hold quit, Menu, and the rocker down key. Then press and release the power on key. release the rocker down and wait for the welcome display. Now release the quit and menu keys.
3. If you have to perform a full reset using one of the sequences shown above you will need to allow the unit to collect a full almanac before normal can be resumed. First a fix will need to be obtained which can take from 5 to 10 minutes of leaving your unit outdoors, stationary, with a good sky view. After the first lock you will need another 12.5 to 15 minutes to get the almanac reloaded. Check the date to insure that the information was reloaded properly. Time will be shown as UTC time since your local time offset was lost in the reset.Re-establish all of your preferences such as time zone, daylight savings flag, etc. Reload all your waypoints and saved routes from your backup. I do hope you have a backup.
4. Something which you shall know about your GPS system for future uses :-
click and save them
http://www.gpsinformation.org/dale/secret.htm#reset
http://gpsinformation.net/etrexlegend.htm
If you face any problem with resetting or taking a backup or regaining your resolution back to normal. just give me the version and model of your gps. for deeper solution. Remember if you are using it in a very cold place the inbuilt thermomast is going to show effects. consider that point before resetting it. If you have recently shifted to a temporary location where temperature is freezing then I'd recommend to let me know the facts. I'll generate another temporary solution for this place.
Posted on Jun 30, 2009
  • Aruna Singh
    Aruna Singh Jun 30, 2009
    I tried my best to solve your problem the only mistake which seems, i did, is giving the direct link. No issues, I'll also ask the admin to cancell your question. Which can be only done from your side.
    Thankyou for using fixya.
    Brigadier General:
  • 3,917 Answers
The gps would 'dim' possibly if unplugged, but it would also ask you (via screen prompt) if you wanted it to stay on. If not, it would shut off in 30 seconds.
First thing..have you tried issuing a full reset to the unit (reset button in the back) then plugging it in to the car, letting it sit for a second and then power it up?
OK, I've managed to overcome the problem I've formated the micro SD card and now it works without any glitches .
Thanks for contacting Fixya.
Not getting power to the starter
that happens
what work has been done on the car recently
check battery cable to starter is sound
tight battery terminals
if starter motor clicks ..flat battery
if starter wont turn at all
possible faulty starter
or immobilizer is still activated
Oct 14, 2016 | Cars & Trucks
How do you wire up 4 6 volt batteries in a 1976 kenworth. 12 volt lights 24 volt starter
When you go pos to neg from one battery to the next it increases voltage, pos to pos just increases amperage. You would want to wire 2 in series, just imagine stacking batteries in a flash light, pos from one to neg on next. Remaining pos and neg are 12v now. Run both remaining pos to starter and ground both negs. your pushing a lot of amps with the batteries and doing 12v, and your charging system is 12v. If you do another series from there, you have to regulate the voltage when the starter kicks in...you risk burning every light and electric component...just like running 12v in 6v system... You can also use 4 12v batteries and run all pos to pos and all neg to neg and have mega cranking amps...that is how all modern big trucks are set up. Your pushing around 7k cranking amps that way(1500 per battery)...plenty to start the healthiest cat... And don't have the worry of dual voltages or running in series. You really don't need 24v to start and unless you have a 24v alternator, these are your 2 options. Best bet if your not sure is to try with 12v...no risk of frying anything even on 24v system. 24v on 12v system is, on the other hand, a big risk. 43bf17ec-4e37-4a15-a147-d1e7a1377d9f.jpg
Jun 03, 2014 | Cars & Trucks
No Power In Electrical System
CHECK THE BATTERY VOLTAGE, SHOULD BE 12V OR BETTER, THE CLOCK DOESN'T NEED VERY MUCH POWER, THATS WHY IT'S THE ONLY THING WORKING.CHARGE THE BATTERY.GET A BOOST.
Jun 04, 2013 | 2007 Qlink Commuter 250
Stanley 300 amp jump-start system status lights don't work. only low stays on
Sep 26, 2012 | Stanley 300 Amp w/12V USB Jump Starter -...
I have no sound coming from my sub or my back speakers. all the fuses are fine and all connections are fine as well and the blue light on my amp is on. and the it seem the power light and protection light...
With the radio OFF, take a jumper wire and connect from the 12V input to the remote input of the amp to see if it powers on.(BE CAREFUL NOT TO TOUCH THE GROUND). If it does, your remote from the radio is either cut somewhere, or not working at all. If it doesn't turn on then turn on the radio and do the same thing with the jumper wire, if it turns on, then your 12V power from battery is not working, maybe a blown fuse by the battery?
Jul 28, 2011 | Car Audio & Video
Cant get remote wire to turn on amp. it is running from back of kenwood deck to kenwood amp.
OK ! FIRST THINGS FIRST. DID U TEST THE AMP FIST. BEFORE U STARTED INSTALLING RCA CABLES,AND REMOTE WIRES. LETS DO THAT FIRST.GRAB YOUR AMP.SET IT ON YOU WORK BENCH ,TABLE,OR CHAIR.THEN GET (2)PIEACES OF #10 OR #12 WIRE W/1 OF THE WIRES HAVING A 20AMP FUSEABLE LINK ON IT.NOW THE WIRE W/THE FUSEABLE LINK ON IT.CONN THE REMOTE(REM) AND THE 12v + ON THE AMP AND HOOK THEM BOTH TOGETHER ON 1 SIDE OF THAT FUSEABLE LINK WIRE. AND THE OTHER WIRE HOOK IT UP THE - GROUND SIDE OF THE AMP .NOW PICK UP YOUR AMP OPEN UP YOUR HOOD.MAKING SURE THAT NO WIRES OR THE AMP IS TOUCHING THE + 12V OF THE BATTERY. NOW CONN YOUR GROUND TO GROUND AND THE FUSEABLE LINK ON THE +12v SIDE OF THE BATTERY.NOW THE AMP SHOULD HAVE CAME ON. LOOK 4 A SOLID RED LIGHT OR ANY SIGNS OF A SOLID LIGHT THAT HAD CAME ON.
Feb 21, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Turned the key to start '99 Dodge Ram 1500, after 1 second of turning over, hand slipped & key turned off. Immediately turned key again to start, now the buzz sound of the fuel pump is lower in volume,...
Hello
The 1st thing to do is make sure the battery is not defective and that the battery post and cables are clean and free of corrosion and making a good connection, even if they seem ok clean them with a battery post and cable eyelet cleaning tool, they are available from any auto parts store for around $4.00, while u are there bring the battery with u and have it tested it is free at any of the many so called discount auto parts stores , these new sealed battery types can go just like that, one moment they crank the engine fine the next not, very common, have seen it dozens of times.
Dec 03, 2009 | 1999 Dodge Ram
Sounds problem
First things to check:
  1. You changed the fuses on the amp, but have you checked the fuse that is inline on the +12V wire? Most of the time, it's right near the battery terminal.
  2. Do you have +12V at the amp's power terminals? If not, either your +12V or ground line has a break or disconnect.
  3. Try taking a piece of wire and connecting it to both the remote connection of the amp and the +12V on the amp. This should cause the amp to turn on (if all is well). If not, the issue might be internal to the amp and would require professional repair.
Mar 13, 2008 | Directed 1100d Car Audio Amplifier
Amp
Unfortunately, I can't find the manual for that amp online, so I'm flying blind. If there's anything similar to "system control", that is essentially the same thing as the remote.
Another thing to try is try connecting the +12V wire to one of the "+" inputs at a time. If one of those connections is the remote, hooking +12V up to it but not the other will cause the amp to not turn on. If the amp turns on no matter what "+" input you put +12V on, then we know both "+" inputs are probably are just for +12V.
It's also possible that the DIN plug has the remote as one of the connections in it. Don't know that without the manual.
But, if the amp really, truly has no remote wire connection, you'll need to get a SPST switch or relay to turn the amp on/off. Otherwise, without a switch or remote, your amp would be on 24/7 and drain your battery in no time.
Mar 10, 2008 | Car Audio & Video
Garmin 010-00468-00 GPS Map 76Cx Handheld/Portable System With Americas Detailed Base Map GPS Receiver Logo
41 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
