Question about Landmann Grilling
Landmann ltd outdoor heaters assembly instructions
Landmann ltd outdoor heaters assembly instruction. I don't know if i have all the parts. Is there a piece that fits on the center pole that goes into the drum and to gas bottle
    New Friend:
  • 15 Answers
Noggin
  • 944 Answers
SOURCE: Broken piece connecting timer and thermostat
These are the guys you need to speak to; http://www.esalton.com/control/contactus 1-800-233-9054 Hope this helps - please ask again if you get no luck from them :)
Posted on Apr 15, 2007
SpotBert
  • 231 Answers
SOURCE: instructions
http://www.charbroil.com/Consumer/ProductGuides.aspx
Posted on Dec 26, 2008
SOURCE: I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Posted on Apr 09, 2009
  • 3 Answers
SOURCE: Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
Lbogie68
  • 158 Answers
SOURCE: no instructions for landmann 1273602
Try this link, rate me if it satisfies you I would appreciate it
http://www.landmann-usa.com/customer-service/instruction-manuals/fire-pit-instructions.aspx
Have a good day!
Posted on Mar 25, 2011
Need assembly instructions for a jackaroo flinders 4 burner bbq
It is a discontinued product so you are probably going to have to just lay all the parts out and guess. You could also look for assembly instructions for a similar BBQ made by Weber. They all follow a logical sequence.
I did find reviews, you could ask if anyone has the manual and when you ask a question, the question is sent to those who have reviewed already.
Jackeroo Flinders 4 Burner
Dec 28, 2015 | BBQ Guys Grilling
Just built my grill chef 12736. Every thing is fine except it has come with two right hand doors. Do you know where I might get my hands on a left hand door?
That's got to be a bummer. Brand new grill get it assembled and find one wrong door. The best bet, is go back to or contact the retailer you purchased it from. Also, check the Owner's/Assembly Manual for a number to call if parts are missing. Most manufacturers provide this feature now. As a last resort, contact Landmann, the manufacturer http://www.landmann.de/LANDMANN_Holding/en/kontakt/
Hope this helped you. Good luck & Happy Grilling!!
Jun 27, 2011 | Landmann 12376 Gas Grill
Can you tell me how to put together the landmann 923738302 bbq please i have lost the instruction maual
As I know this model sell by Aldi store.
Sorry I can not find out english version for you.
Use Sweden for replace, the sharp is the same
http://www.landmann.se/files/man/se/12373.pdf
May 17, 2011 | Landmann Grilling
I need instructions to assemble landmann gas bbq 12736
For you ^^
http://www.landmann.co.uk/lanotattachments/download/file/id/4/store/1/12736_instruction_manual.pdf
Apr 17, 2011 | Landmann 12376 Gas Grill
Can you supply me with an instruction manaul for a Landmann 3 burner gas bbq with side burner (grill chef 12736 not sent with box
download in from landmann UK
Mar 27, 2011 | Landmann Grilling
I need assembly instructions
Download this file
difference name but the same design.
Mar 26, 2011 | Landmann 12376 Gas Grill
Where can i get assembly instructions for great outdoor tent
You can get instructions for Great outdoor tents if their not too old from Great Outdoors Hastings
Dec 22, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Grilling Logo
226 people viewed this question
Top Landmann Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Landmann Grilling Expert? Answer questions, earn points and help others
