Question about Canon PIXMA MP150 All-In-One InkJet Printer
I have a problem with MP160 error E22, would you help me how to fixed this problem.... thanks'
  • nanang_k82 Jun 30, 2009
    Thank you for your answer I'll do it\
    thank you for your opinion
    once again thank so much
  • 10,515 Answers
E 22 is a carriage error, which means there is still something wrong in the cartridge area.
Please do as follows:
Turn off the printer and unplug it.
Remove the cartridges. Check them for leaking or damage.
Look carefully inside the cartridge slots. Look for dried ink or blobs of ink (they can be cleaned away with a tiny bit of alcohol on a qtip. Look for bent or broken cartridge wire holders? Does everything look okay?
Leave the cartridges out. Plug the printer back in and turn it on.
Does the carriage move?
Reinstall the cartridges and make sure they are properly seated.
Close the lid. Turn off the printer
Restart your computer.
Turn the printer back on.
Thanks.
Posted on Jun 30, 2009
2 Suggested Answers
geemarie
  • 876 Answers
SOURCE: E22 error code
Tell me what is happening now. unless everything is okay!
Posted on Aug 24, 2008
E22 error on Pixma MP160
It could be, if it leaked over the contacts, or dried up for lack of use, it could easily throw this error.
Jan 03, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Tip
Code error PIXMA MP160 All-In-One InkJet Printer
this error list PIXMA MP160 /150 All-In-One InkJet Printer
CANNON PrintersMP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported inkcartridge is installed ,
or the ink cartridges are notinstalled properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera /video camera does not support Camera
DirectPrinting
E14 The Ink cartridges whosedestination are wrong
E15 Ink cartridge is notinstalled E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature riseerror
E27 Waste ink absorberfull or platen waste ink absorber full
E28 Ink cartridge temperaturerise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
on Mar 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
When scan arise error code 2,250,0 canon MP 160
this error does not exist, perhaps "E22" means "Carriage error" or "E25" means "ASF(cam) sensor error"
Mar 08, 2011 | Canon PIXMA MP160 All-In-One InkJet...
The Cannon MP160 shows E22. I don't know whats wrong with it
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
Feb 05, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My canon mp160 got a error 5100 or E2. I have tried several solution: uninstall and reinstall the driver, reset the printer, shake the ink cartridge but still it won't work. Please help..
E2-2 = No paper (ASF) and E22 = Carriage error
steps from canon website 1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Reseat ink cartridge (MP160 / MP180 / MP460)
5. The MP160 may require repair
if you need further assistance please let me know, Thanks midwest-tek
Aug 31, 2010 | Canon PIXMA MP160 All-In-One InkJet...
ERROR E22 ON MY MP160 PRINTER
E42 22 = Scanner error
Aug 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E22 in my MP145
Error E22 = Carriage error
to reset this error follow the steps below--
with the printer powered off but connected to a power source , you must:
1. Press stop/reset button, and then press [ON/OFF] button to restart
2. Press [ON/OFF] again and then press twice the stop/reset button.
3. Press [ON/OFF] & Stop/reset button together, this time to enter the repair status and power lights will be green,
4. Press stop/reset button 4x and warning lights will be go out in [ON/OFF]button.
5. Turn off the printer.( it must be turn off) and then turn it on again.
Use with your own risk ,
i’ll try this way and my Pixma MP145 not blink again.
The number of the Reset button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5 Unplug cable power. (for MP145 / MP150)
6 Turn Off Power. (for MP160)
Note if the above steps did not work's means you need to check your Carriage;
Hope this helps...
Good Luck!!!
Mar 23, 2009 | Coby Audio Players & Recorders
Canon mp 160 service error 5100 & e2-2
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-25
Dec 21, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E22 error code
Aug 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
How to fix e22 error
ive already change the carriage but it still doesnt work and it say's that it is in the mantenence progres (is not sinish) i cant print or scan !
can you halpe my?
Mar 11, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
684 people viewed this question
old marine
old marine
