Built-in camera flash is not working. How do you repair it?
It's not repairable unless you are competent to strip down the camera and you can get the part. There is no way of knowing if it's the inverter which supplies VERY HIGH VOLTAGE TO FLASH TUBE and beware the storage capacitor can remain charged even if the camera is off, or if it's the tube itself. The spares will cost nearly as much as a new camera. Dismantle intuitively and look for any loose cables or wires, if not an obvious loose wire then move on. Also camera is old now.
SOURCE: instuction manual for a Camedia Digital Camera C-725 Ultra Zoom
Hi - You can download the manual by clicking the link underlined in blue below:
C-725
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
SOURCE: Need date stamp on pics
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order or print reservation that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Camedia Master or Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
SOURCE: is there a vista driver for the olympus CAMEDIA c-460
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
SOURCE: My new memory card will not work for the Olympus Camedia D-560
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb card is not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
