Question about Pool & Spa
My fimco gold series pump leaks. put new diaphram
My fimco gold series pump leaks. put new diaphram in and leak got better but still leaks.
  • 1388 Answers
SOURCE: air compressor leaking
The problem that you are having is caused by the in tank check valve not holding the tank pressure. Simple test is to carefully loosen air-hose that feeds air to tank and check for air leaking. Replace check valve if leaking. Generic parts may be used. Enjoy
Posted on Dec 07, 2008
SOURCE: Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Posted on Dec 13, 2008
  • 1118 Answers
SOURCE: Power steering pump still leaks after putting new one in.
the bubbles are just air in the system, it will eventualy go away. are you sure the leak is from the pump or is it just comming out the cap because of the air. also did you chk. the pressure line? that maybe where your leak is. unless you got a crack in the resavor, its most likely the pressure line. there is a pressure line and a return line.
Posted on Jan 28, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
Posted on May 10, 2009
SOURCE: I also have a FIMCO 15 gallon 12 v spot sprayer, won't prime
I use an emulsifier with Round-up to make it stick better to the weeds (Sticky Spreader). The emulsifier had made the solution less viscous and was not moving through the wire mesh filter that comes out of the bottom of the tank. I removed the filter and it works fine. I have a filter in the handle anyway so there is no need for two filters for my application.
Posted on Jun 06, 2009
I have a kitchenaid quiet scrub dishwasher that fails to function. When you close the door and press the start button the clean and cancel lights come on and the pump starts up. No water enters the...
ther is a small impulse pump on the bottom of the unit. the diaphram gets old and it stops functioning but sometime then it leaks . so if it's not leaking , turn off water suppl and remove the fitting for incoming water some have screens right here and they get plugged with hard water debris . ha dont be silly all water is dirty.you can get new screens at h/d and lowes, hope your solenoid still works, check it by putting a finger on it when the cycle should start it should humm or vibrate. diaphram is not replaceable. need to buy new valve
Sep 06, 2012 | KitchenAid Dishwashers
I fill it up and it takes two or three days to leak out.I have tried stop leak and dye,check all the hose connect with water in a spray bottle. Is there a other test i can do.
If this is a water leak check water pump diaphram (the hole in the bottom of pump) if you see water around this area replace water pump.Also check water pump gaskets for leak.Or have it pressure tested.
Apr 22, 2011 | Chevrolet Blazer Cars & Trucks
The cap on my fuel filter was taken off and the parts don't seem to be back in the right way. It's an '82 golwing gl1100. Can anyone tell me the right position of the internal parts (over the diaphram)....
The fuel filter is located under the carburetor and is mounted to the front of the fuel tank about 6 inches from the fuel petcock. If some one has installed an aftermarket fuel filter on your goldwing you should consider putting the original filter back on. It is of excellent quality and should do a much better job of filtering the fuel than a rebuildable/cleanable style filter (they are prone to leaking).
If you are talking about the fuel pump on the rear of the right cylinder head it is only sold as an assembly (no parts are available separately). If the diaphragm is being pushed up by the arm try rotating the motor to lower the pump arm and see if it allows you to put the cover back on correctly.
Dec 05, 2010 | 1982 Honda GL 1100 Gold Wing
Old craftsman model 358352151 with 145 blade - starts with fuel added to carb but will not continue to run - new fuel line, fuel filter and gaskets - ?? why - is carb ?
if you have good compression and spark and spark at the right time and mufler and ex port are clear and you have rebuilt the carb correctly and fuel lines are not pinched anywhere
check you have put the pump diaphram on 1st then the gasket and cover, and made sure the inlet screen is clear
check you have set the meter lever flush with chamber floor and have fitted spring under the lever correctly
and fitted the gasket then then metering diaphram and the cover
lo and hi screws should be set to 1 1/4 turns out from lightly seated as a base setting
check the manifold gasket and carb gasket for a air leak or a crack in insulator block
then check for a air leak at base joint or crankcase seals
2 strokes crankcases need to be air / vacuum tight in order to draw in and pump mixture let alone operate carb diaphrams
always remember F A C T S
F = fuel A =air C = compression T = timming S = spark
then primary compression ( ie air tight cases)
have a recheck and let me know what you find
cheers pauly46
Sep 09, 2010 | Garden
Pump has no pressure
scrub up the check valve within the pump really well, that should help restore the prime! use dish soap and a toothbrush!
Jun 30, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Jun 05, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I got a 79 ford with a 351M and it will start for a bit then die as soon as i give it any gas i put a new fuel pump in and fuel filter and it still is doin this do you think that it is the acceration...
maybe the float in the carburator or timing also check for fuel leak because you have a pump that sucks gas to the motor if any leak it would **** air to carb
Jul 28, 2008 | Ford F-150 Cars & Trucks
Pool & Spa Logo
115 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
