Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Check in main menu (set and box if using one) under closed captions--one of the settings is TEXT--black box will appear in middle of screen and certain channels--with the remote turn text off.
This is the closed captioning text box. Search the menus to turn off closed captioning. The reason for its seemingly random appearance is that not all channels nor all programs provide this service.
Do you recieve any channels if you run the cable directly from the wall to the TV and do a channel search? You may have to switch your TV over to a different input source if you are using a box. Please email me at tina-AT-suddenlink-DOT-com for more information. Thanks!
you have a closed caption type tv. Search your tv menu (maybe via the remote control) and look for an entry called closed caption, I'm guessing it is set to TEXT. either set it to OFF, or set it to ON if you want to.
I can only suggest that you Double check you have the connections correctly set ie. coax ariel to ,(dvd /digi box reciever ect...)
Also check again (& i know this is state the obvious)
your tv manual. IF you havent a manual do a google search for your tv (make & model) & search for a manual.
Ive have had a simmular experience when programming channels to a Vid-Recorder & when i finished the channels dissapeared.
I realised I didnt have the video set to the correct channel with the tv usually channel 9 or the highest channel on the tv.
So i waisted a good half hour for nothing.
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text" Please be advice that CC :Text is the ONLY one that can give you a black box.
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
