Question about Amana ABB1927DE Bottom Freezer Refrigerator
Ice build up in freezer. Then leaks on to the floor.
  • 40 Answers
Possible reason is leakage at the door gasket.Not properly closing door.it has to be checked.
Posted on Jul 01, 2009
Ice maker leaks on floor when I turn on after awhile
Hello:
is the water coming from the ice maker for sure?
It could be that you may have clogged defrost drain line and the water has no where else to go but the bottom of freezer..Defrost happens roughly every 8 hr or so...
Jul 11, 2017 | GE Refrigerators
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
There is ice build-up on the floor of the freezer. If I don't chip it out, it will leak onto the floor in front of the freezer. Any suggestions?
check that the door seal is an air tight fit all around the door,,if hot moist air is getting into the freezer this is were your getting the ice from,,,also check that the thermostat is working if its not cutting out the freezer is working flat out full time,,thats a lot more ice build up
Jul 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice is jamming on external dispenser. open the door and ice falls all over floor. what could it be?
my freezer is leaking water all over the floor it can come ok for a few days then starts again also build up of ice inside freezer any ideas how to solve this??
Sep 09, 2009 | LG Refrigerators
Ice build up on the bottom of freezer
Check to see if after clearing out the ice sheet, that the gasket for the door is tight against the freezer. If air is leaking by the gasket, it will build up really quick.
Jul 09, 2009 | Kenmore Refrigerators
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Ice build up on the freezer floor then leaks out the door
thats the THERMOSTAT , is defective , this unit is connected underneath the freezer floor , when you remove it your gonna see like a black thick line running all around the freezer floor ,every 4 or 6 hours this line heats up avoiding ice to build up on your freezer. hope this info helps
Apr 18, 2008 | Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
204 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
