Question about Garden
I have a portable water pump with a Honda engine that won't start
I have a portable water pump with a Honda engine. The On/Off switch is not working any more. How do I connect them without that switch or bypass the switch in other words? There are 3 wires connected to it, two black ones and a yellow one.
  • 634 Answers
You should not bypass this switch but rather replace the switch bring the switch to electrical store and you can get a replacement for under $10 or sometimes u can find on at marina store or rv store
Posted on Jul 17, 2009
2000 Honda Valkyrie Interstate will not start
Hi, Brian the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
DOA Won start
Won start unless in Nuetral GL1500 Information Questions goldwingdocs com
Honda GL1500 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda 1997 GL1500C Valkirie Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 12, 2018 | 2000 Honda Valkyrie Interstate
Throttle linkage is loose and when started water does not come out the nozzle after BEING BLED OF AIR
The unloader on your pump is bad...this is causing both problems. Find your pump model # ...probably an AR pump ...they fit the Honda GC engines well and go to this site Pressure washer parts catalog quick links Pressure Washers High Pressure... they can guide you to the correct unloader... Good luck
Jan 19, 2014 | Powerboss 020309 3000 psi 2.5...
Washer will wash but won't spin after wash to finish load
Does the water drain after it finishes the wash before the spin is supposed to start? If yes then it can be that the timer is faulty or the spin windings in the motor have burnt out.Does the pump work at all when this has happened, or is the machine completely dead?Let me know please.I also need to know whether it's a digitaly controlled machine or works with a mechanical switch.
Apr 18, 2013 | Whirlpool LCE4332PQ 22" Portable Compact...
Honda s-wing 125 won't start
Hi, Chris and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch lever, or kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
New battery but Bike still won start
Scooter Troubleshooting Scooter won start All about Scooters
Honda 125 Scooters SH SES NES PES FES 125 2000 2009 Haynes Motorcycle...
http://www.partsfish.com/page/oem-parts-for-honda
http://www.honda-montesa.es/manuales/FES125_150_07.pdf
Nov 18, 2012 | 2011 Honda SWing 125
1986 honda goldwing won't crank
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
1985 GL1200 Won crank start or turnover
tried starting 84 with low battery won start now GL1200 Information...
Honda GoldWing GL1100 Service Manual
Honda Gold Wing GL1100 Owner Manual
Aug 09, 2012 | Honda GL 1100 Innerstate Gold Wing...
1998 honda accord shut off while driving and won't start; next day it does.
One common problem with Honda cars is the fuel pump relay.
I would check that first. Do you know if you have spark to the plugs when it won't start ?
Jul 25, 2012 | 1998 Honda Accord
Pump won't run
Did you figure this out yet? If not.
Did you check the onboard GFI breaker switch?
Did you make sure the water was connected and turned on?
Jul 11, 2012 | Stanley Portable 1600 Psi Electric...
Hi, Im working on a 92 CBR600 F2 for a friend. Bike is ruff. Chain broke and balled up at front sprocket and busted sprcket cover. I managed to get water pump back i and held down. The problem is it wont...
Hi, Mlovern890 the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Motorcycle won start while in gear with clutch squeezed CBR Forum...
http://www.fireblades.org/forums/honda-cbr-600/66884-1993-f2-will-only-start-neutral.html
Honda cbr600 1991 1994 service manual
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/CBR600F-1994.pdf
Apr 12, 2017 | 1992 Honda CBR 600 F(2)N
Doesnt build pressure up ,it just runs right without pressure does the compressor require being oiled?
HELLO THERE:
Here is some troubleshooting tips for you and a web link for you ok this should help
best regards michael
Troubleshooting Your Pressure Washer troubleshooting_pressurewasher.jpg General points to check if a problem occurs
  • Are the engine and fuel switches in the “ON” position?
  • When troubleshooting, always check oil and gas levels.
  • The oil for the pump is a 30W non-detergent mineral oil. Do Not fill over halfway on the sight glass.
  • Is the water tap open?
  • Check the choke and throttle levers.
  • Is the correct nozzle in the lance? Is the nozzle plugged?
  • Only the black nozzle is for soaping at low pressure.
  • Is the water-inlet screen clogged?
  • Hold the gun trigger open while pull starting the engine.
  • Check for O-rings in the lance and quick couplers.
  • Has the unit tipped over? Close the fuel switch and keep pull starting the engine until the excess fuel is burnt up, then open the fuel valve and try again. Some engines will need to be primed every time they are started.
  • Make sure the engine is turned off after each use. It should not be left running without use for longer than 2 minutes as the pump can overheat.
Are you experiencing low pressure?
  • Is there an air leak?
  • Dirty pump valves?
  • Check for worn pump valves or broken valve springs.
  • Check for a worn out spray nozzle.
  • Check for leaks in your plumping or hoses.
  • Troubleshoot your nozzle, is it turned to the highest pressure setting?
  • Is the unloader improperly set?
  • Are the engine RPMs too low?
  • Check if your water supply is sufficient.
  • Check if your engine is getting enough power.
Trouble with high vibrations
  • Do you have a sufficient water supply?
  • Is there are in your water supply?
  • Is the inlet water filter clogged?
  • Clogged or damaged spray nozzle?
  • Make sure it has the correct fuel
  • Has the choke been left on after the engine has warmed up?
If the engine won’t start
  • When troubleshooting the engine, check if it's low on fuel or oil?
  • Worn or dirty spark plugs?
  • Is the switch in the off position?
  • Is the fuel valve in the off position?
  • Is the engine flooded from over choking?
  • When cold starting, was the engine properly choked?
If the starter is hard to pull
  • Low oil in the crankcase or pump assembly.
  • Oil or fuel in cylinders (hydro locked).
  • Pressure built up in the system, relieve this by squeezing the trigger.
Sep 15, 2009 | Honda Garden
Honda water pump
normally all the water pumps coupled with portable gas powered engine have 3000 - 3600 rpm
May 19, 2009 | Honda 8 HP Engine
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
