Question about Creda W120VW Front Load Washer
Creda front loading simplicity washing machine,leaking out of right side, checked the pipework and seals, all seem ok, has it got a filter i should be emptying?
    Sergeant:
    Champion:
  • 353 Answers
Is your pump on right side ? if so that could be your problem
Posted on Jun 30, 2009
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
We have a second hand Creda Simplicity W100 washing machine and want to know if it needs to be connected to both the hot and cold water supply or if just the cold can be connected
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Jan 17, 2010 | Creda W100FW Front Load Washer
Creda W220VW front loading washing machine leaking from bottom of casing. Hoses seem OK, coluld filter need cleaning? If so, how do I access?
Check water flow rate into soap drawer , if very fast water can overflow and run down back of fascia panel and out underneith
Nov 01, 2009 | Creda W120VW Front Load Washer
I need a manual for a Creda Simplicity 1000 washing machine as I have mislaid mine
In your browser bar, type in:WWW.HOTPOINT.CO.UK.
Click on after sales, and follow links.
Pease rate my solution.
Thanks.
Jun 30, 2009 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Water leaking from bottom front panel
Plug off the wall. Open the back of the machine to take a good look at the tube coming out from the bottom of the tub, open the front door to see if the door washer is loose somewhere. You could even try to reach out thru the back to locate any loose rubber gasket, the door gasket that is...... Possible you could take out the top of the machine to see if any of the normal 3 tubes entering your dispenser has come loose.....
Sep 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Creda W120VW Front Load Washer Logo
103 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
