Question about Whirlpool LCE4332P Top Load Washer
I have a whirlpool model# lce4332pq1, portable washer. it was working fine, but sometimes wouldn't drain. i had to do it manually, by taking off the drain hose and 'catching' all of the water. last night i used it twice with no issues, then again and it wouldn't drain and the water level light is blinking. i emptied all of the water that i could, unplugged it, left it a while, plugged it back in; same thing. light blinking, nothing working.
  • 4 more comments
  • jcrosslan658 Jun 30, 2009
    where is this part in the machine? can i clean it out myself?
    i did. it doesn't tell me anywhere where this part actually is in the machine and if i can clean it myself rather than buying a new part. more assistance than a google search has been requested and paid for.
    i didn't get a good answer. i need to know if i can clean this out myself, and how to do it.
    i really don't see how this answers a specific question that i have about a specific washer. again, these are search engine responses that are way too generic.
    next!
    seriously now... you're just copy pasting answers!! is there anyone here who actually knows what they're doing?
    and exactly how do i clean this out?
  • 11,896 Answers
Either the pressure switch is bad or your drain has a clog somehwhere
Posted on Jul 01, 2009
    President:
  • 987 Answers
Http://www.repairclinic.com/SSPartDetail.aspx?s=t-541811-%3d%3di541811&PartID=541811
go to this link and IT MAY BE CLOGGED AND NEEDS CLEANED OUT THIS IS A LINT CATCHER FOR WASHERS
Posted on Jun 30, 2009
    President:
  • 392 Answers
GO TO www.repairclinic.com AND LOOK FOR PART 541811, u need to replace it , then it will work coninously .. hope this solves.plz rate my solution.
  • 583 Answers
I will give you few links to disassemble the unit and get the required part
just click the links directly
and in that all the options will be listed just select the required option and click the answer will be in front of you
http://www.applianceaid.com/direct.html
this is the another link
http://www.applianceaid.com/beltwasher.html
check out this both links 1 by 1
this will help
keep updated for more help.
thanks.please do rate the solution.thank you for using fixya.
    Sergeant:
  • 326 Answers
GO TO www.repairclinic.com AND LOOK FOR PART 541811 IT MAY BE CLOGGED AND NEEDS CLEANED OUT THIS IS A LINT CATCHER FOR WASHERS
  • SABARI ANAND
    SABARI ANAND Jun 30, 2009
    yes please go to the corresponding website
2 Suggested Answers
  • 686 Answers
SOURCE: water still in tub water level light blinking
Posted on Apr 17, 2009
My portable/compact Whirlpool washer drains, but won't spin water out
Check on Youtube for removal of the pump clips and motor clips. It really only takes a flat screw driver for each clip and a 1/4 socket too for the motor clips, as you tilt the machine back to get at the parts.
Feb 20, 2014 | Whirlpool Washing Machines
This washer machine is about 4years old it's a whirlpool model # LCE4332PQ1 and the problem that I'm having is that it's making this loud noise when it's rinsing in on the finally rinse it don't drain
Almost sounds like a bearing going out, but that wouldn't address the no drain situation. My bet is a sock has lodged itself between your basket and tub. They usually end up covering the drain whole. Sometimes they work their way down into the hose between tub and pump. There they often work themselves against the propellers of the pump. Check that the hose is clear and pump functions correctly before attempting basket to tub disassembly. Also look really closely with flashlight at the drain holes at bottom of basket, you may be able to see it if it's between basket and tub. If you can see it try to move it towards drain hole with a straightened coat-hanger. If you can get it there i think it is just a matter of removing the hose from the tub end on your model and grabbing it with some needlenose pliers. Keep in mind i'm going from 20 sec. of video here, so i could be way off base. Hope this helps.
Dec 30, 2012 | Washing Machines
Washer wont drain
When my washer wouldn't drain I pulled a sock from the discharg filter. Check your filter and make sure it's not plugged. If that's not the problem then your washer pump isn't working for some reason.
Jun 03, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't drain properly
when ours wouldn't drain, my husband had to take ours apart and in the filter was a small rag that somehow went under the basket that blocked the flow. Since then, drains fine.
Apr 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer LCE4332PQ1 leak underneath.
it sounds like that a pipe as become loose or corroded or the pump housing as perished you could take the back off and watch what is happening but mind your hands as the washer machine has many moving parts and elec parts as long as you don't put your hands anywhere near it when the back is of you will be fine but always unplug the machine before you do any work
Dec 07, 2009 | Washing Machines
Water still in tub water level light blinking
Apr 16, 2009 | Whirlpool LCE4332P Top Load Washer
PORTABLE WASHER LCE4332PQ1
did you fix this? i have the same problem.
Apr 06, 2009 | Whirlpool LCE4332P Top Load Washer
Whirlpool compact washer won't drain
check the pump, usually has an item that is lodged into the impellers
Feb 16, 2009 | Whirlpool Laundry 22'' 2.1 Cu. Ft....
Kenmore 44722
You need a new circuit board. Sorry, no way around it, the board needs replaced. You didn't mention how old your machine is.
Jul 22, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Whirlpool LCE4332P Top Load Washer Logo
153 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
