Where is the pressure switch
SOURCE: hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
SOURCE: Hotpoint WT960 User Manual
Try the following link:
Andrew
SOURCE: hotpoint wt960 comes up with test all the time
Press the Start/Cancel button until all the console Led's Illuminate
Press both Start/Cancel and On/Off buttons together until 'd off' appears
Normal screen should return and you can select a new programme. (GL = good luck)
SOURCE: Hotpoint WT960 Flashing F-05
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
SOURCE: I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
