Question about Samsung SyncMaster 920NW Monitor
I have a samsung 920nw monitor bought it new. It has worked great for months, this morning I went to turn it on and it only came on for a second then turned off. I have restarted the PC and the monitor repeatedly with the screen only coming up for 1 second then going black w/ the indicator light staying on not blinking. I've connected it to my laptop with the same result and even unplugged it from the PC just to see the check signal cable screen and it still only stays on for 1 second. Please help
  • Samsung Master
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 17, 2009
I have a samsung 920NW Black 19 monitor that will not stay on beyond 2-3 seconds. I've check cables and tried on two different computers with same result. Is the monitor ready to be trashed? I found a...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault. It can be repaired, all you need to do is just to replace the picture board on the monitor, after replacing the picture board, you will see that the monitor will work fine, just as before.
Take care.
Jul 17, 2010 | Samsung SyncMaster 920NW Monitor
Hi I Got a Samsung SyncMaster 920NW the display
If you are saying that it powers off in a few seconds you most probably have a bad (internal) power supply.
Jul 12, 2010 | Samsung SyncMaster 920NW Monitor
Flashing power button on Samsung SyncMaster 920NW
Yes, More than likely the problem with the unit is blown capacitors on the power supply board, the flashing power light is a good indicator of this type of failure. Here is a link to a repair guide with pictures and videos showing how to open the unit and what to look for and replace to get it back going again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
BuddyMc
Feb 12, 2010 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
The repair guide has pictures and videos to guide you through the repair.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Fuzzy/blury fonts on a samsung syncmaster 920nm
Good morning! Please review/check the set-up settings of your samsung flatscreen, best to refer it to the operations manual of the monitor which should be included when you bought it. best regards.
May 02, 2009 | Samsung SyncMaster 920NW Monitor
New moniter too dim.
Good morning! Please review the operations manual of the unit, taking note of set-up settings value requirements. best regards.
Mar 20, 2009 | Samsung SyncMaster 920NW Monitor
Good morning! kindly review the operations manual included when you bought the unit, takeing note on the best set-up settings of the display properties. Otherwise, you may opt to set it to other resolutions that will support the best display. best regards.
Aug 12, 2008 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920NW Monitor Logo
459 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
