Question about Stanley Bostitch F21PL Nailer
I have a bostitch SB 16 finish nailer that has a rack of nails stuck in th loading barrel. I need to take the barrel apart to get them out, How do I do this?
  • byrdman39 Jun 30, 2009
    I can't find the four bolts referred to in the solution.
    byrdman39
    .Yes. Please mark the bolts you are referring to.
    Thank You,
    byrdman39
The solution provided is harder then it needs to be. Where the nail gun handle attachs to the nail magazine there are 2 bolts. Remove these bolts and the nail magazine slides right out and you can get to the jammed nail. It still took some effort on my part to get the nail out but this was a lot easier then removing the 4 bolts previously suggested.
Posted on Dec 30, 2009
    New Friend:
  • 131 Answers
Take the bottom 4 bolts off the nose. And it will pull away from magazine. So you can remove jammed nails.
Thanks,
Jeff
Posted on Jun 30, 2009
  • yoopertech Jun 30, 2009
    This would be the 4 bolts that bolt the nose piece to the body of the tool on the bottom. Flip the tool upsidedown and you`ll see them. Do you need a schematic?
    Regards,
    Jeff
Bostitch SB-1850BN. I bought a bundle of nail guns over a year ago, today I go to use this gun for the first time and just get a very poor poof of air coming out, no nail. I've tried it with pressure in...
At the end where you attach the air hose is the nailer imprinted with the words "add oil"? If so; add a few drops of oil designed for air nailers.
Also check to make sure no nails are stuck in the tip of the nailer and the return mechanism is reset.
Oct 20, 2017 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
What degree nails are used in stanley bostitch n60fn nail gun
I've repaired many nail guns and I can tell you the Stanley Bostitch N60FN uses 15 guage nails from 1 1/4" to 2 1/2" long in the FN1500 series of Bostitch nails. Nowhere does SB or any of their aftermarket dealers list what the angle of the nails is. I do know most of the SB nail guns that come through for repairs are because of damage to them from using other than SB series nails.
Oct 01, 2012 | Stanley Bostitch Nail Gun
How to load bostitch sb1664fn nail gun
Push on the button on the rear of the tool to open the magazine. Pull the magazine back. Load nails in the stationary part of the magazine with the heads of the nails at the top of the magazine. Push the sliding section of the magazine back into place making sure it latches.
Jul 04, 2011 | Stanley Bostitch FN16250K - 2 16 - Gauge...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
I bought a used Bostitch nail gun. Model/serial # N6408406208021. What parts do I change to go from a 1 1/2 inch nail (approx. #6) to a 3 inch nail (approx. #16)? Where do I get the parts?
I do not think that the n64 will take a 3" nail. N64 will most likely fit a 2 or 2 1/2 inch. To verify the length of nail open latch door and measure the width of the slot into the barrel. Take a look at the bostitch n80 series of nailers for more power and longer nail.
Dec 18, 2010 | Stanley Bostitch Coil Framing Nailer
The driver on my Bostitch nail gun won't retract
This is usually caused by either a lack of lubrication or a defect in one of the seals. If hte nailgun has been uised a lot, purchase an O-Ring kit and replace all of the O-rings. That should resolve the problem. I believe that these kits are available for around $20-$30.
Dan
Apr 12, 2010 | Stanley Air Tools & Compressors
I have a SB-1850BN Bostitch finish nailer that no longer shoots nails. I think it may be a o-ring in the cylinder but not sure. Is there an easy fix for this situation?
Generally speaking an O-ring kit will resolve this type of problem. Check with your local lumber yards that sell Bostitch products. They may have a Bostich Day at which, for a purchase of nails or some other Bostitch product, the manufacturer will give up to 2 tools a quick overhaul including replacing the O-rings.
Dan
Jan 11, 2010 | Stanley Air Tools & Compressors
We have a Bostitch nailer that leak out of the end
there are o rings inside the nail gun, remove the allen head screws and get replacements.
Apr 10, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Stanley Bostitch F21PL Nailer Logo
560 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
