Question about Water Heaters
Last night before I went to bed there was water in my kitchen sink. This AM, there is water working in the rest of the house, however, no water coming out of my kitchen sink. I removed the aerator(sp?) and that didn't make anything magic happen. I looked under the house and saw no sign of water leaking. What could it be?
  • 1 more comment
  • chadsgirl374 Jul 14, 2009
    Yes. I replaced the faucet after noticing that the sprayer that formerly did not work was now working. Our problem is now solved :)
    Thank you for responding :)
  • Bill Johnson May 11, 2010
    do you know how to take this faucet apart?
  • George Sararu Feb 02, 2013
    The termostatic swich broke a spring and completely close the hot part of the faucet! replacement is the only feasible alternative
  • 297 Answers
Is this a single handle faucet? if so your cartridge may be clogged.If not your supply line is clogged,check the valve also.
Posted on Jul 15, 2009
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Rinnai RC98i Error 12 - Flame Failure
IF THIS UNIT HAS SPARK IGNITION THE IGNITORS ARE PROBABLY OUT OF ADJUSTMENT WHICH IS LIKE HAVING TO WIDE OF A GAP ON A SPARK PLUG . IF YOU MAKE GAP OF IGNITOR ELECTRODES APPROXIMATELY 1/8TH OF AN INCH APART IT SHOULD LIGHT AS LONG AS YOU ARE GETTING VOLTAGE FROM IGNITION COIL. CALL A SERVICE TECH
Dec 22, 2013 | Rinnai RC98i Tankless Water Heater 9.8 GPM...
My kitchen sink has been not working properly since last Monday anyone can suggest me good or reasonable plumber?
I think you'd have it repaired by professional plumber. I know one plumbing company, which can deals in residential as well as commercial properties. They've vast experience in this field over fifteen years. http://www.ps2i.biz/plumbing-systems-solutions-company-info
Jun 11, 2013 | Mountain Plumbing Water Heaters
I have the exact same problem, house is only 6 years old, two handel faucet, Ive turned off the cold side to eliminate it, turn on hot and have to run at full blast and it takes a full 10 minutes to get to...
You have a clog in the water line?
Or a faulty check valve or mixing valve?
Add a comment and say how you fixed the problem, or add more information about size of pipes.
It seems like the cold water is getting into the hot water line somehow. There is no other explanation, as much as I can see from 800+ miles away.
If you have crossover on a single-handled faucet where the cartridge is bad, that can cause this problem.
Slab house can have plumbing in attic. It can be a chore to drop poly pipe down into walls, but it can be done with angle drill. Assuming walls are 8 foot high and pipes can be easily dropped to sink level where the sheetrock is removed and new pipes tied into sinks and tubs.
This kind of DIY project would take a couple weeks working a few hours each night when temps cool off, depending on size of house and number of affected faucets.
I live in Houston on a slab and ran my pipes in the attic when I built the house. Of course I worry about broken pipes collapsing the ceiling and filling the house with water, which happened to lots of homes one year when temps dropped to 4 below. I was in the painting business at that time, which was a boon to business for a few weeks.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 17, 2010 | Laing Thermotech Autocirc Undersink...
It just stopped working last night. Gas kitchen stove works fine. Are there pilet lights on these things?
if its gas, it has a pilot light. the most likely thing is the thermal coupling is bad. if it is bad, burner flame will not turn on. it senses the tempurature to send gas to light burner.
Aug 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
My water pipes froze thursday night so friday night when i went to bed i left the tubs hot water turned on and they thawed out about 2am i got up and turned the tub faucets off the water was hot at that...
you probibly ran the hot water tank out of hot water shut off the hot water comming out of your fausets for a few hours and check it again u could also try to reset your tank by pulling off the front cover and hitting the reset button and my last thought is sadly you burnt out your heating elements and they need to be replaced good luck man
Feb 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Bosch ae125-re tankless water heaters
My experience in Germany with tankless water heaters was not good; the delivery promised was only vaguely warmed water; they are no replacement for standard devices.
If you can find closet or under-counter (in the kitchen) space you might look into the 20 gallon units made for RVs or small mobile homes/campers. They are not expensive to run and cost well below the ~ $400 US price I saw when looking at the Bosch. If you are worried about the efficiency of them or concerned with the cost of electricity in your area, you could have an electrician install a high-capacity (15-20 Amp) toggle switch (looks like a normal light switch) and manually turn it off completely when it is unused for a longer period of time.
In any case, before you jump on the Bosch bandwagon, check the degree (or lack) of satisfaction from current owners:
http://www.amazon.com/review/product/B0006GVO0S/ref=dp_top_cm_cr_acr_txt?_encoding=UTF8&showViewpoints=1
I wouldn't be encouraged to buy that one.
Sep 18, 2008 | Bosch PowerStar AE125 AE125 Whole House...
Water Heaters Logo
63 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
