Question about Karcher K2.26 Electric Power Washer
Karcher k 2.36 smoking and flashes of light inside the machine.
Hi, i used my karcher k 2.36 for 45 mins and then it started smoking and flashes of light started to come inside the machine. Can it be fixed or will i have to buy a new one.
  • 174 Answers
Hi:
This sounds like a short circuit or motor problem. They are relatively easy to take apart. If you see a burned wire or connector this can be repaired. If not, it is the motor and probably too expensive to repair considering the price of a new one.
Posted on Jul 01, 2009
Whilst using my karcher it suddenly flashed very brightly in the case and then went bang and i could smell smoke is it worth trying to repair
You could try taking the cover off and check if it is just a wire come loose and touched something, i have in the past bypassed the on/off switch when it has sparked and blown.
Oct 17, 2016 | Karcher Garden
The amber RM10 and RM11 light is flashing on my karcher 7/10
Regarding this model, I am not that informed. But similar machines, it is an indication of water softener warning lights. If it is a fuel problem and machine is full of fuel, then the fuel level sender, is faulty.
Regards,
MG.
Feb 12, 2015 | Karcher Garden
Karcher wont start
there is a pressure switch in those machines that goes bad. it is a common problem. if its under warranty let them work on it. if not take it apart and you will see the problem. it is replaceable and you can do it.
Mar 28, 2014 | Garden
Hoover dyn9144dg washing machine door lock flashing wont start.....lock changed still wont start.....light still flashing
Hello the
Plesre and welcome to fixya
can i ask you a question did you unplug the machine and leave it sit for at least 1 hour
See these machines have a internal computer that stores information like any settings that are in the programed in the machine
It normally takes any where from 45 min to at least 1 hour to compete the memory loss on the computer thus resetting the computer ok
so please tell me if you did this if so there is more that we can do ok
Best regards michael
Dec 10, 2013 | Washing Machines
My karcher 645 has three lights on the right side of the control panel. The bottom one that looks like a heater temprature warning light keep flashing when im using the machine. Is this normal or do i have...
I'm not a karcher dealer, but I'll comment. I'm assuming you've misplaced your owner's manual -- so the only way you'll know for sure is to contact karcher.com..... or a dealer.
That said, I'm pretty sure your blinking light is just bells and whistles kind of stuff. It most likely is a reminder that its time to change the diesel filter. Which means it has some "re-set" procedure. I just wouldn't worry about it.
Don
Mar 07, 2012 | Karcher Garden
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Smoking after start up
If it's the org. engine it will has over 160,000 miles on it.
It's normal to has valve stem seal/oil seal on the head to leak oil into the cyclinder on high mileage engine.
The smoke you see is the motor oil drop from the valve stem seals. The oil drops land on the top of the cyclinders and it create black smoke at start up.
The inexpensive fix is to start using high mileage oil with seal conditioner.
This will help soften the rubber seals and help reduce internal oil leak.
The correct fix is to wait until it's time for a head gasket replacement and let the professional CRC/service the head.
Complete head service is the only method to stop this internal oil drip problem.
Oct 29, 2008 | 1994 Mazda MX-3
Metz 45 CT 1
I had that same problem also, but mines was temporarly. Ik think the condensor inside the Metz has to regeneratie (recover) itself by using with a full charged fresh batteries. The high freq. sound is normal. (although not to loud) after a 5 MINUTES the orange bulb should light up. How more u used how better the start-up time. My old Metz start-up time was around 40 sec. and now ot is within 7 sec.
Jun 22, 2008 | Metz 45 CL-1 Flash
Karcher K2.26 Electric Power Washer Logo
1,321 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
