SOURCE: polaroid i735 digital camera troubleshooting
wat dHa fudqee kiiinD 0f sO0lutii0n **** R U GiiViinqqqqqqqqq????????????????????????
RAWR rqqqqqqqeeee
u knOweeee help qurlllleee bOyyeee
w/e
SOURCE: polaroid digital camera i830
the warranty wont cover the screen they will tell you its your fault and they wont do anything.
SOURCE: free/ need a manual polaroid digital camera 530
You can download/print your FREE manual here:
http://www.polaroid.com/media/document/a530_ug_en.pdf
SOURCE: My new i1236 Polaroid digital camera will turn
1) The card could be write protected, check the side of the card see if there's a small notch to slide up or down.
2) The camera could have photo protection option switched on, you have to go through the user manual and the camera menu to switch that off.
3) If you don't get too far with the first options, as its new, take it back to the vendor and ask them to demonstrate it to you and to your satisfaction. If there is a problem with the camera, request a replacement or refund under warranty.
Testimonial: "Thanks for your help, I'll try it."
SOURCE: polaroid i733 digital camera lens stuck open
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
