Question about Fellowes SB-99Ci Shredder
Fellowes SB-99Ci shredder won't work after jam cleared
4 sheets of paper somehow managed to jam up the Fellowes SB-99Ci shredder, whereupon the control buttons which would normally allow you to reverse feed the paper to clear the jam did not respond. The power was then switched off (for safety reasons obviously) and the jam manually cleared, but now it won't switch back on.
5 Suggested Answers
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
  • 329 Answers
SOURCE: Powershred 380-c
Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
Posted on Jun 24, 2008
  • 215 Answers
SOURCE: Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Posted on Apr 15, 2009
  • 811 Answers
SOURCE: how to change gear kit
You can get a manual for this device here not sure what information the manual will provide for you would not hurt to check it out, also a good observation of what is needed to remove and replace this item is also something to write down where things go. The kit should have had instruction manual of how to install the kit. Check out the site above. Thanks for using FixYa! John
Posted on Mar 10, 2011
Cause of "stall" during routine shredding letter head paper
Lack of grease on the internal gears. accumulation of small bits of paper causing the motor to slow down and stop.
May 25, 2015 | Fellowes Powershred SB-99Ci Heavy-Duty...
CAN THE BLADES ON A FELLOWES 99Ci SHREDDER BE SHARPENED?
I do not believe so. Never heard of sharpening one. The shredding blade is pretty complicated. The manufacturer has a good support web page I suggest contacting them. Keep it clean and oiled and it should last a long time. And do not shred stuff listed on the cannot shred list.
Feb 06, 2015 | Fellowes SB-99Ci Shredder
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Fellowes 58-99C - unit is on, power is on, the on/off button will not turn on.
This unit has a bin power actuator switch, if the bin is not in correctly or the post that turns on the switch is broken the unit will not turn on.
Aug 29, 2011 | Fellowes SB-99Ci Shredder
Fellowes SB-99Ci Shredder Logo
2,511 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
